wiring 1.7L SOHC stock ECU nonVTEC-to-Vtec Swap
I just did this my 2005 Civic LX (non VTEC) blew up and replaced it with a 2003 Civic EX VTEC Motor, Trans, wire harness and ECU
Some of the wires are a little different between the 2
There are differences between the Motor harness and the body harness.
All good after flash from Honda
Keys work now with the ECU that matches the motor need to do this if you change the ECU. The motor ran on the LX computer just thew codes for the O2 sensors.
Only code its throwing was the heater on O2 sensor 2 which if you get the harness from the motor there is no place to connect the Downstream O2 sensor as the exhaust is different between the 2 motors. I changed my exhaust also, used a aftermarket LX header back exhaust and just added the 2nd O2 sensor about mid car and left the plug in the header for O2 number 2. You will also need the O2 sensors for the EX motor as they are different between LX and EX
Wired the Black/Yellow wire to pin 5 yel/blu on connector E
Wired all O2 stuff to connector E and all good now, No codes
So just so its cleared up for anyone else doing a LX - EX conversion in a 2001-2005 Civic here is where the wires are landed when using EX Motor, Trans, Wire Harness and ECU
Here is where they are on the stock harness Connector A (31 pins)
25 wht/red Secondary O2
23 brn/yel Logic Ground
14 blk/wht SecondaryO2 sensor heater control
10 grn/yel Sensor ground
Blk/yel Heater acc power
Here is where they go on Connector E (31 pins)
2 wht/red Secondary O2
3 brn/yel Logic Ground (Shield from O2 Sensor)
5 yel/blu Sensor voltage (attach to blk/yel from O2 Sensor)
6 blk/wht SecondaryO2 sensor heater control
Connector A (31 pin)
On the wht/red and Blk/wht
I dissected the old harness to get the whole wire with the metal ends that fit into the harness. As you will find out when going from LX to EX there are a few different wires and they are not in both body harnesses the same way. On the other wires I just tapped in and soldered and taped as not to cut the factory wiring.
I hope his helps anyone that might be doing the same swap that I needed to do to get my everyday driver back on the road with a few upgrades.
Received 1,442 Likes
Rep Power: 338 Re: 1.7L SOHC Non-Vtec Swap
jcb111,
pretty good instructions for wiring a VTEC engine - worth making it a separate thread and sticking it to the top
thanks!
moderators
thanks!
moderators
Re: wiring 1.7L SOHC stock ECU nonVTEC-to-Vtec Swap
Further to JCB111's post.
Connector A is the grey connector and connector E is the white connector.
Attached is an image for the connector E wiring:
The following users liked this post:
Tsx413 (08-23-2023)
Sorry for this but did you cut from one connector and soldered them to the other connector cuz I. In the middle of doing the same swap and a lil lost
Do you have a picture of the o2 sensor you added. also what o2 from the Ex do I have to get. Is it the up stream or down stream. Thanks for your time.
With the JDM motor you have to swap a few other parts over from your existing motor. I forget exactly which ones I moved over.
I had a Donor harness with my new motor and I cut the wires out of the old harness to use in the new locations.
As far as programmers I know nothing. I had Honda flash my new computer to work with the new motor.
Please note I had a D17A, wire harness and ECU from and EX model car
If you do not have an EX ECU your vtec will never kick in. The car should still run on the LX tune just not as good. I drove mine to Honda with the OLD ECU in and at Honda replaced the LX ECU with a EX ECU
As far as the harnesses to a search on the forum thats how I figured out which ones to use. I know someone has posted picture of the plugs for this process. I used to have pics of the harness and plugs but that was a long time ago.
Hope this helps
Hope this helps
Move your wire harness to the new engine.
Your engine likely does not have a EGR, does the new one have it? Might need to move your intake / water passage to the new engine.
Your alternator works, move it to the new engine.
Transmission is a hard one, new one will cause concerns for your PCM as the gearing is different and the PCM will think something is broken look for all the work arounds.
Move your timing belt, tensioner spring, and water pump to the “new” engine or even better replace then with new parts.
That JDM engine is 15yrs old and the “low mileage” claim insures that those parts were never replaced since it was made.
Hi am in the middle of trying to figure this out i've been reading your post over and over trying to understan it mine is a 2001 civic lx non vtec and I swap it with a vtec engine I have the vtec harness and ecu right now am running it with the non vtec ECU the only code am getting is for secondary o2 sensor , should i be able to use your rewiring metod if I keep the stock exhaust and header or do i need to purchase an after market exhaust, I should of just gone with the non vtec engine it would of save me all the headaches lol😀...
Are you talking about the actual ex wire harness or is this the original body harness, I’m in the process of switching my exact car over.
I used the EX motor harness and the LX body harness. I cut up my old LX motor harness to get the downstream O2 sensor harness to wire in.
my JDM motor doesn’t have a pressure switch next to the Vtech solenoid, do i need to add pressure switch?
Yes you need to swap one to the JDM motor. I also swapped a few other parts from the EX motor but don’t remember exactly. I had a USA Ex motor for parts.
So did you use factory LX upstream o2 sensor and factory ecu pin locations for the upstream? And then use factory EX downstream o2 sensor wired to connector E?
i dissected the LX upstream wires from the LX harness.
tapped that into the EX harness for the Downstream O2 wires.
Please try and follow the instructions as posted.
i don’t have this car anymore so I can’t go check to verify for you.
also bought 2 EX O2 sensors. The LX ones will not work
hope this helps
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
03-28-2022 07:35 AM
