Transmission swap post information/Questions about automatic to Manual Transmission swaps
Manual to Auto
Old Oct 27, 2020
Lenovo's Avatar
Lenovo is an unknown quantity at this point
Manual to Auto
Hi hello to all,
Manual to Auto swap on d17 VTEC any experience and cost
Old Oct 27, 2020
GolNat's Avatar
Prelude Owner
Re: Manual to Auto
Just sell it and buy an automatic. It can done the other way so I don’t see why it couldn’t be reversed.
Old Oct 27, 2020
Colin42's Avatar
Re: Manual to Auto
Usually people want to go the other way (auto to manual)
The amount of time, money, and effort involved will greatly exceed the value of the car. Go buy a car with the trans you want
Old Oct 27, 2020
FRSam's Avatar
Click Here
Re: Manual to Auto
Plus automatics are typically cared for better than manuals. Manuals are typically worth more than automatics anyway so you'd probably end up making money by just changing cars.
Old Oct 27, 2020
Re: Manual to Auto
@mac25
Old Oct 29, 2020
Lenovo's Avatar
Re: Manual to Auto
Thanks all for value advice ..
Old Oct 30, 2020
mac25's Avatar
Dr Krieger of Modification
Re: Manual to Auto
I swapped auto to manual, and only because I already had other modifications/wanted to learn about transmissions.
time wise you're looking at 1 to 3 days, 1-3 8 hour shifts including snacks and clean up. This depends on your organization and familiarity with the vehicle.
You will also need 1-2 hours at a scrap yard to pull everything.
In my case since the manual transmission has no relationship with the pcm/ecu I was able to drive in limp mode down to honda to recode my key and change out the ecu.
I'm not sure if that will work for you though, you might need to tow the car to honda to reprogram the key to the pcm/ecu.
or maybe if you have a second key/ignition/ecu you can bring them those ahead of time. Not sure though.
Old Nov 4, 2020
Lenovo's Avatar
Re: Manual to Auto
Thanks bro for advice
Crovax
Transmission swap
Dec 12, 2016 02:11 PM
hondapower84
Oct 5, 2010 12:16 PM
scooterist50
Jun 4, 2007 12:17 AM
cerebrous
Engine Swaps
Nov 1, 2005 04:37 PM
2k1civicExCoupe
Oct 20, 2003 06:53 PM
