Re doing my whole suspension
Old Apr 13, 2017
SlowboyZ's Avatar
SlowboyZ is an unknown quantity at this point
I already have new shocks and struts, ball joint, control arms. I'm trying to figure out how many bushings does each control arm have? I'm going on a road trip and I bought a front suspension kit. Anything else that I'm missing when I'm getting new parts for suspension? I'm just looking for stock performance.
Old Apr 13, 2017
Re: Re doing my whole suspension
Each front lower control arm has 2 bushings.
The bushing at the front of the arm (the larger of the two), called the compliance bushing, is the one that frequently goes bad and causes knocking noises as the LCA comes in contact with the front subframe.
You may need swaybar links, they might get destroyed taking the LCAs off.
Also, wheel alignment after the suspension is done, before the road trip. Don't want to eat up a set of tires.
Old Apr 13, 2017
SlowboyZ's Avatar
Thanks for the reply ezone. Did I get it all parts correctly when it comes to the suspension? Struts, shocks, LCA, bushings, ball joints, tie rods. I'm assuming new LCA come with new bushings.
Old Apr 13, 2017
Depends.
How many of the suspension parts ACTUALLY have issues/needs replaced? (thinking overkill unless it needs everything LOL)
Of what quality are the replacement parts?
You said you already have the new parts...open the box and look.
A friend gave me a set of ball joints for my truck....along with some other suspension parts (from a parts store that is open on Sunday ).
The ball joints on my truck right now are original, the boots are torn but the ball joints themselves are still good.
I have a little over 150k on my truck.
The new parts are made in China.
Would the new Chinese parts fail sooner than the originals would (made in Japan) if I left them as-is? How much sooner....they might fail in 30k?
I don't trust white-box-made-in-China parts. These were FREE to me and I still don't want to install them.
I might consider swapping out the new rubber boots and keep the original joints though.
Old Apr 14, 2017
OneJzSupra's Avatar
OneJzSupra is an unknown quantity at this point
If you don't have the lower control arm parts.... I would look at rockauto and just buy a whole lower control arm with bushings already.
