Steering problem
Old Oct 8, 2011
Ronbroom's Avatar
Ronbroom is an unknown quantity at this point
Steering problem
My 03 civic power steering seems to give out for a few second when I'm stopped for awhile then move. It don't happen all the time but its annoying idk if my pumps goin or something else.
Old Oct 8, 2011
Re: Steering problem
any whining sounds? fluid okay not low or dark?
Old Oct 8, 2011
Ronbroom's Avatar
Theres no whinning and the fluid is OK but I'm not sure of the color ill check after work
Old Oct 10, 2011
ZFreak's Avatar
Honda Crazy
ZFreak is an unknown quantity at this point
The pump could be going out. Try waiting until you have the hard spot, then rev the engine a little.... does it get easier? If you have fluid and correct level, and the pump isn't making a "whirring" noise, then the pump is probably on its way out.
Old Oct 11, 2011
Ronbroom's Avatar
OK thanks ill try reving it next time it happens
conspiracy90
Jun 7, 2023 01:01 PM
honda200192
Suspension
Oct 27, 2019 12:23 PM
honda200192
May 31, 2015 05:57 PM
anddrrey
May 11, 2015 02:30 PM
jakeconnor
May 5, 2015 07:30 AM
