Brakes Post Your questions about brakes here!
code 61
Old Jan 10, 2021
jayjay_23's Avatar
New Member
jayjay_23 is an unknown quantity at this point
code 61
guys, my abs light is on,. and it gives me a code 61 says ignition voltage.. where is the ignition voltage located? thanks
Old Jan 11, 2021
BrotatoChip's Avatar
Super Moderator
Re: code 61
Checked fuses? Anything look wrong with the wiring going to the ABS module?
Old Jan 11, 2021
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: code 61
Check the charging system. Failing alternator, battery, poor ground to the alternator through loose mounting bolts etc.
FWIW, the ABS light on is one of the first indications that I had a failing alternator. Changed alternator and all is good.
luke02civic
Aug 11, 2005 08:05 PM
Tofoo4life
Feb 2, 2003 03:49 AM
vdub
Dec 13, 2002 09:06 PM
Dustman380
May 10, 2002 12:15 PM
