Tranny cooler lines clip?
Old Mar 2, 2019
Kristoliquid's Avatar
Kristoliquid is an unknown quantity at this point
Hey, I'm getting the condenser, radiator and fans off.
On the bottom of the radiator are two small lines. Both held with some oem clips. They are not like those big spring clips found on the bigger coolant lines. You can see two ears sticking out side by side. How do I go about to get those things off? Thanks.
Also those the 10mm bolts holding the lines on the condenser broke, can I unbolt them where the other connection connects?
Old Mar 2, 2019
Re: Tranny cooler lines clip?
I got the bastards, was just a clip thingy.
And I just wiggled the broken bolt ac connecting out.
dayglo77
May 30, 2010 01:41 PM
brian02
Oct 17, 2009 01:24 PM
ricergribbs
Bolt-on Engine Performance
35
Nov 28, 2004 01:04 PM
CivicMexicano
Aug 6, 2004 07:30 PM
gearbox
Jul 18, 2004 06:59 PM
