2001 civic auto trans problem
Old Dec 22, 2016
Michael Siletti's Avatar
Michael Siletti is an unknown quantity at this point
Car in 1-2 gear only mode. No cruise control. Swapped radiators. Hooked up all lines and connectors. Next day trans shifted this way suddenly. 2001 civic Ex 1.7 L 4 SPD overdrive. Trans fluid replaced 2 months ago with OEM Honda fluid. No back flush here. Drain and fill 12 quarts. 4 changes 3 at a time. Any one know the input voltage to the ISS OSS and VSS sensors. Also how to check Sensors themselves for Resistance. Looked online for electrical diagrams.
Problem started day after Connectors and lines pulled of and reconnected.
Old Dec 26, 2016
mac25's Avatar
Dr Krieger of Modification
Re: 2001 civic auto trans problem
Possibly swap the line positions over?
Old Dec 26, 2016
Got a check engine light on? Flashing "D" light? Got fault codes?
I'd kinda suspect the trans cooler in the new radiator wasn't perfectly clean and a chunk of solid material made its way into the trans.
Or...was a used radiator installed? Same deal.
Old Dec 28, 2016
mililani's Avatar
mililani is just really nicemililani is just really nicemililani is just really nicemililani is just really nice
Interesting. I am just about to replace my radiator too. I've read online people were starting to notice their AT transmissions were slipping/flaring after changing to some aftermarket radiator. Are you using aftermarket or OEM?
