Interesting way of flushing an AT transmission
Old Jun 14, 2010
mililani's Avatar
mililani is just really nicemililani is just really nicemililani is just really nicemililani is just really nice
Hi folks,
I'm new here. Long time lurker, first time posting. I have a Honda Civic 2001 LX. It has about 110k miles on it and is due for a transmission fluid change. I've read that Honda recommends three drain and refills. I was browsing around and found this video:
http://www.youtube.com/watch?v=MsdPAadc9fY
Basically, the guy suggests that you drain the transmission and clean out the metal shavings on the drain bolt. He fills up the transmission with new fluid. Then he finds the transmission coolant supply line and removes that and hooks up another line to a bucket or reservoir. He then starts the car. The idea is to let the engine flush out all of the fluid from the tranny and torque converter into the reservoir thereby clearing out ALL of the tranny fluid. As the engine is dumping out the old fluid, the new fluid is added to maintain, more or less, the level of ATF in the tranny. When the engine starts pumping out clear fluid, the engine is turned off, the fluid levels topped off, and supply line reconnected.
So, has anyone tried this before? Thoughts?
Old Jun 14, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Interesting way of flushing an AT transmission
This is an awesome way to clog the internal filters on the transmission. Which will restrict oil flow and destroy it over time. On a car with an external filter that's great but our civics have an internal filter which cannot be changed without opening the transmission.
Old Jun 14, 2010
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
Anything at the bottom of your tranny will now be in your filter after the flush so you will have to change the filter. Bad move on our cars. Your best move is to drain, refill and then repeat. Hell if your that worried about stuff at the bottom of your tranny you could always open the bottom drain plug and fill the tranny from the top and let it run out the drain untill it gets mostly clean. Sounds like a big waist of fluid to me.
And if your tranny has thgat much stuff in it you have bigger problems then just needing a fluid change.
Old Jun 14, 2010
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
I don't think there would be a problem with clogging the filter. All you are really doing is adding clean ATF. If adding fluid is causing particles to be loosened and circulated then that will happen no matter if the old fluid is drained from the pan or the cooler line.
A couple of things in the video make me uneasy. First, I don't like using Dexron fluid in a Honda. I know he is doing it because the manual says you can use it in an emergency and because it is cheaper and he plans to do a second flush with Honda ATF. No flush ever removes 100% of the fluid so some Dexron will remain. I would just do a single flush with Honda ATF. I have heard other people suggest a slightly different method in which the line going to the cooler is placed in a bucket like the video but a second line is attached to the return line from the cooler and placed in a large, clean container with fresh ATF. The difference is the transmission is sucking clean fluid at it's own rate instead of pouring it down the filler tube and hoping you keep up or don't overfill. You simply stop before all the fluid is gone from the clean fluid container.
My Civic is a MT, but I also have an Integra and Camry that are automatics. In both the ATF got a little darker than I liked before I realized it. In both I did 3 drain and fills each about a week apart to get the fluid clean again and now I do a drain and fill every 10k miles and the fluid looks perfect.
Old Jun 14, 2010
BlueEM2's Avatar
Whachya lookin at?
^ I'm not reading your whole post because it's long. I assure you, it plugs up the internal filter. You drain the bottom of the tranny which is full of shavings and debris and jam it into the filter which would in no way happen anyway. It's your choice, but it will destroy the transmission. The only time you ever flush these transmissions is if they are coming out of the car for repair. That's Honda's own recommendation.
Old Jun 14, 2010
mililani's Avatar
Yeah, that's pretty creative putting the new fluid into the receiving line to maintain equilibrium of the fluid. And I agree. I don't see how debris and shavings on the bottom of the tranny will be perturbed by this method. Wouldn't the tranny do that when the clutch is engaged? I digrees. I'm no transmission expert. Oh well, tbohar seems to disagree with this method. Honda also recommends the drain and refill method.
Old Jun 14, 2010
mililani's Avatar
Tbohar, I mean this as no offense, but how do you know this for a fact? Are you a Honda certified mechanic? Just curious.
Old Jun 14, 2010
CrewChief's Avatar
I say its your car and you do it your way. You are obviouly convinced that it will work.
But I ask you please report back to us when your tranny filter being clogged blows your tranny. the fliter is before the coller lines and the fills back through the tranny. Think of it like an oil pickup and oil fliter or a return fuel system. Same concept. The more nasty **** you unearth from the tranny the more your filter picks up.
But I stand by saying that if you drain your tranny fluid and there is metal shavings in your tranny you have bigger problems than dirty fluid.
Old Jun 15, 2010
BlueEM2's Avatar
Whachya lookin at?
Honda knows these cars better than me, and you. They say to drain and fill for a reason. So, drain and fill unless you want transmission issues. The reason they recommend this is so the oil at the bottom which has the shavings does not pass through the filter. I'm going to leave this at that because you will do what you want anyway, and I'm not going to argue it. I'm going to use my better judgment and listen to the engineers with many years of education who get paid way more than I do and designed the system.
Old Jun 15, 2010
BlueEM2's Avatar
Whachya lookin at?
Well, I just put some thought into this and this method would be pretty similar to a drain and fill. You would not drain all the old fluid out though. I don't understand why you would ever do this when the drain and fill is so easy. Not only is it less risky because you don't have to start the car but you also don't have to remove any cooling lines. I guess if your not draining all the oil out and your pulling oil out of the return line on the tranny you shouldn't pull shavings, hopefully. I'd stick to drain and fill though.
Old Jun 15, 2010
filter clogging aside, adding a whole 9 qts of new fluid to an old trans with deposits is gonna cause alot more problems than only changing 3 qts with new fluid and still having alot of old mixed in. less chance for a big fail. i hear it all the time. trans is fine, they do a flush, then its slipping afterwards. and there is no going back, youre screwed until a rebuild.
Old Jun 15, 2010
mililani's Avatar
Well, I guess I'm going to stick with the drain and fill method. Sticking with the Honda recommended way.
Old Jun 16, 2010
BlueEM2's Avatar
Whachya lookin at?
Glad gearbox chimed in here, he is the guy that knows
Old Jun 18, 2010
pjb3's Avatar
I'm not a big fan of transmission flushes. In many cases I think that shops push then as a profit center. They bought the machine and it needs to make money. To make matters worse some push a "flush" instead of just a fluid change. For a flush they run a fluid that is supposed to clean deposits and condition seals and then they replace the ATF. I agree that if a transmission has been neglected then a flush that removes deposits is NOT a good idea, especially if you can not replace the filter. At the same time I don't think that just replacing the ATF should cause a problem.
The one time I would recommend a fluid exchange with a flush machine is if the fluid is badly contaminated or burned. Most flush machine leave 10 to 15% of the old fluid behind while changing 3 qts of ATF 3 times in a transmission that hold 9 qts leaves 29% of the old fluid behind.
Old Aug 10, 2010
TXFred's Avatar
TXFred is an unknown quantity at this point
I ran across this thread while researching the transmission oil change on my 04 DX.
I have a question. Why is a large amount of new transmission fluid a bad thing? Is the old fluid beneficial in some way?
Old Aug 10, 2010
02civicsi02's Avatar
Low and slow!
This method will clog the filter and cause alot more damage than you think just trust us ok. And like gearbox said flushing an old tranni is a very bad idea especially with that much fluid. Even honda recommends not to flush a high mile tranni cause it will cause the tranni to mess up and slip. You are only suppose to flush the tranni with low miles. Just drain and fill like you are suppose to.
Old Aug 10, 2010
BlueEM2's Avatar
Whachya lookin at?
^ I wish I could agree with you but you aren't supposed to flush even a low mileage transmission. During the manufacturing process and first few thousand miles a lot of shavings build up in the transmission casing that will clog the filter just as quickly as with an older transmission. So, you aren't supposed to flush ANY transmission Not in our civics anyway.
Old Aug 10, 2010
Low and slow!
True but Honda does say to flush it only with low miles. I have never flushed any of my transmissions and never will unless I have to crack it open and rebuild it or something like that.
Old Aug 12, 2010
mililani's Avatar
Uhhhh, new transmission fluid is never a bad thing. Old fluid is definitely not beneficial. If there was a way to get all of the old fluid out without clogging the AT filter and replacing it with new fluid, that would be the best route. However, since the Civic AT is designed with a built in filter, nearly unreplaceable filter, you can't do it. After reading johndeerebones' thread on his tranny problem, I can now understand why people on here are against the aforementioned method on flushing the tranny fluid.
Old Aug 12, 2010
Nosepicker's Avatar
Nosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the rough
Link please.
Old Aug 12, 2010
Low and slow!
We are all against it because honda says not to flush the tranni easy as that.
Old May 22, 2012
Neosangria's Avatar
Fully full on Noobsauce
Neosangria is an unknown quantity at this point
doing the 3 quart interval drain and refill..Honda recommends driving a "short distance" in between drains. What constitutes a short distance to everyone? 5 miles? 100 miles?
Old May 22, 2012
i did at least 30 mins of city driving in warm weather. most important thing is to frequently shift thru the gears from 1-4, R, P, etc and get the fluid warmed up and mixed.
Old May 24, 2012
Neosangria's Avatar
10-4 plan on doing all of this during the weekend. Whats the ATF gonna set me back? The nearest Honda Dealership is 20 miles away and whoever is answering their phones in the parts/service department needs to be drawn and quartered..
Old May 25, 2012
if you have 2010+ civic, prolly go with honda dw1 atf. if you have older civic, go with valvoline maxlife dex/merc. it works better than the discontinued honda z1. the dw1 is full synthetic and i would not recommend using it in an older trans. you can get a case of maxlife around $80 at the auto store. should look like this, do not get the stop leak version.
Old May 25, 2012
Neosangria's Avatar
So the Valvoline is okay to use on an 04 VP auto tranny then?
Old May 26, 2012
yeah it says right on the back it works where z1 is called for. so 01-05 civic auto should be fine. ive used it for a year in my 02 auto and it works much better than z1. smoother shifting, faster fluid warmup (lower viscosity), and lasts longer. its a semi-syn like the stock fluid was. if you search around many other honda guys use it as well in accords, odyssey, civic, etc. esp after the original trans died with z1 fluid. ive never heard of a failure due to maxlife.
Old Jun 3, 2012
Neosangria's Avatar
thanks Gearbox, gonna pick some up this weekend. Next project will be finding out whats causing the front end to vibrate. Speeds lower than 50 I'm getting a vibration that never used to be there before. I can feel it in the pedal and when I let go of the wheel I can see it rocking back and forth pretty bad. I've never done any suspension work so I don't really know what to look for.
Old Jun 4, 2012
check the front engine mount first. its located near the header down below and they are very delicate. some ive seen tear apart at only 10k miles. use energy suspension poly bushing inserts for that mount. the other three usually have no problems. but you may get a tiny bit of vibration from the inserts because they are stiffer. after a few months it will feel like stock again tho.
Old Jun 5, 2012
palsana's Avatar
palsana is an unknown quantity at this point
Neosnagria, I have done a full suspension replacement for the front end on my 03 civic ex sedan AT and i have the very same issues that you are bringing up., after 50mi/hr it vibrates in a way that you can only feel it in the pedal and also when you first put your feet on pedal and make it move from a stop sign after a long wait at a stop sign (30secs or less ) it rattles before picking up the gear, it continues not to fall into gear when u push hard on the gas until quite a distance and makes that squeaking/cranking noise not wanting to fall into gear but once you lift your foot off the pedal it will fall into gear and second and keep moving further on very smoothly until u come back to a stop and its the same routine again.
I have had almost three re-builts on my tranny but have never flushed/drained my old tranny fluid ever. Im just advised not to change the old fluids at high mileage (i have 175000 mi on my car). The last re-built was done some 12,000 mi ago and its due for a fluid drain/change.
What does every one here suggest i do?
EDIT:06/10/12; front engine mount with energy suspension poly bushing inserts have not worked on 03 honda civic ex A/T 4dr.
Its gotta be something else? what could it be???
