D17A2 cam bearing issue
Old Dec 1, 2024
Mojesmayne's Avatar
Mojesmayne is an unknown quantity at this point
I bought an 01 Civic ex that needed a crankshaft seal, I decided to do the camshaft seal as well just because, looking at the valve train I saw some light scoring on some of the roller rockers, I got curious and decided to pull the camshaft. So I did and found that the bottom bearing surfaces on the head has some decent scoring that you can feel a little with your fingernail, camshaft is the same but the cam caps are pristine. Would I be fine with a polish of 2000 grit sandpaper or should the machine shop do the work or is it just junk? Sorry about picture quality, I can get some better pictures if need be
Old Dec 3, 2024
BrotatoChip's Avatar
Super Moderator
Re: D17A2 cam bearing issue
I would have a machine shop take a look. They should have a better idea what it needs.
Myredjonda
Apr 14, 2015 07:00 PM
parditty
Engine Swaps
74
Jul 7, 2009 12:00 AM
wikkaco0
Feb 18, 2009 08:14 PM
nongv
Jun 10, 2003 08:23 PM
1028CiViC
Nov 8, 2002 02:49 PM
