Getting a P0108. Cleaned MAP sensor and it's still in limp mode
Old Jul 12, 2020
thesupersoap33's Avatar
thesupersoap33 is an unknown quantity at this point
The idle is sort of funny. I pulled the sensor and cleaned it with electronic cleaner and an air duster and put everything back. It's still giving an immediate check engine light and not letting the car go over 3k rpms.
Should I clear the codes? do I need to clear them and then see if a check engine pops back up?
I think I got my car out of limp mode awhile back just by undoing the negative terminal and waiting a minute and then putting it back. Is that a thing?
Also, I rode around in it for a minute and I'm getting about half my normal mpg. Dont worry, I'm not taking it out again.
Ordered a new part from rockauto that should be here in a week, but I'm still stressed that this isnt the actual problem or something. The sensor was fine before I took off the intake and cleaned it and the egr system.
Please help. Thanks.
Old Jul 13, 2020
Colin42's Avatar
Re: Getting a P0108. Cleaned MAP sensor and it's still in limp mode
Honda's don't like aftermarket sensors
Old Jul 13, 2020
Just ordered a refurbed denso off of Ebay for good measure.
How do you test electrical connections on a car to see if they're working properly?
Old Jul 13, 2020
Colin42's Avatar
Need to know what you should be seeing at each terminal (+12v, +5v, ground, etc) then check with a multimeter
Old Jul 15, 2020
Bought a multimeter today. Going to test them tomorrow.
Might as well test the headlight tomorrow too. Left one is out and I have no idea why either. I had to change out the ignition. Maybe that futked something up?
Old Jul 15, 2020
Voltage reading between headlights is different. One reads 12 and the other reads 9. Is this the issue with one of my lights not working? If so, where is the draw? I replaced my ignition a few months back. Could there be a problem with the electronics on the steering column?
I couldn't get a read on the map sensor plug because the meters tongs weren't small enough.
Old Jul 15, 2020
Just fixed the headlight. It was a lose negative connector in the harness. I just jammed it back up in the plastic end and got lucky.
The reading on the map sensor connector was about 3.5 volts in the center hole.
Old Jul 16, 2020
Paper clips aren't just office supplies.
Do NOT try to jam anything all the way into a terminal. Just touch it.
Old Jul 16, 2020
I was wondering if that was something people did! Thanks.
I did get a read on one if the outlets and on a map, I think it goes ground, voltagevoltag map signal. It was getting 3.5 on the voltage, so I think it should be good. Just need to replace the map sensor and see what happens now.
Old Jul 18, 2020
This is beyond frustrating. Just put in the refurbished denzo map sensor and the light came right back on. ****ing pile of ****.
What else could the issue be? I'm sick of this.
Old Jul 19, 2020
The voltage reading is around 3.5. What is it supposed to be?
Old Jul 19, 2020
Colin42's Avatar
I would guess 5v
Old Jul 20, 2020
Where could the problem be coming from? I'm terrible with electrical stuff.
Old Jul 20, 2020
leok99's Avatar
leok99 is an unknown quantity at this point
Service manual. Good luck
tony2eat
Jun 10, 2010 01:07 PM
gangulyarchan
Mar 12, 2010 10:48 PM
Ek00Si
Buy, Sell, & Trade - Archive
Dec 2, 2009 12:15 PM
2001civic_owner
Mar 20, 2007 05:10 PM
adamzeppelin
May 13, 2006 02:43 PM
