02 Honda Civic
Old Sep 25, 2019
John91816cc's Avatar
John91816cc is an unknown quantity at this point
02 Honda Civic
I have a 2002 Honda Civic LX I change the camshaft sensor and the crankshaft sensor car goes to start and shuts off but the car runs without the crankshaft sensor plug In what is the problem but runs without crank sensor Connected but sputters when over 3000 RPMs
Old Sep 25, 2019
GolNat's Avatar
Prelude Owner
Re: 02 Honda Civic
Did you use an OEM sensor?
Old Sep 25, 2019
Re: 02 Honda Civic
Yes I changed the upstream sensor
Old Sep 25, 2019
Re: 02 Honda Civic
This is my first Honda and I don’t know much about them
Old Sep 26, 2019
BrotatoChip's Avatar
Super Moderator
Re: 02 Honda Civic
Did you use Honda genuine cam and crank sensors? Or did you get them from an auto parts store?
Old Sep 26, 2019
Re: 02 Honda Civic
I got them from advanced auto the most expensive nes they had I believe 90 each
Old Sep 26, 2019
Super Moderator
Re: 02 Honda Civic
We have seen lots of people have issues when using non-genuine cam/crank sensors. I recommend returning the ones you have and replace with Honda parts. Depending on what fault codes you're seeing you could try replacing just one at a time.
Old Oct 2, 2019
Re: 02 Honda Civic
Need help with this
Old Oct 2, 2019
Super Moderator
Re: 02 Honda Civic
Have you replaced the sensors with OEM ones yet?
Another option is to find used OEM sensors from the junkyard.
honda.lioness
Sep 17, 2017 04:19 PM
contevo
May 8, 2015 03:49 PM
ATMJDM01
Bolt-on Engine Performance
Aug 20, 2013 12:09 PM
