2004 honda civic dx
Old Mar 9, 2015
Fox_28's Avatar
Fox_28 is an unknown quantity at this point
Exclamation 2004 honda civic dx
I bought a 2004 Honda civic and it had a blown head gasket and the bolts on the cam were lose and the valves needed adjustment, after replacing the head gasket, adjusted the valves now my car wont start, I torque all the bolts and adjusted the valves to specs, did you have any problem like this in the past?
Old Mar 10, 2015
GolNat's Avatar
Prelude Owner
Re: 2004 honda civic dx
Did you forget to plug in a sensor?
Old Mar 10, 2015
That's pretty dang vague. Did you reconnect the battery?
Does the starter operate?
Cam-crank not correctly timed?
Got compression?
Forgot to tighten the grounds on the thermostat housing?
Old Mar 15, 2015
em2-ed's Avatar
em2-ed is an unknown quantity at this point
Im sure you forgot to plug in a sensor. Guessing the one that that you need to unplug to get the casing off the belt in order to remove the valve train cover. Think its the cam position sensor, probably wrong but car will not start if it is not connected.
jessicakaybby
Apr 20, 2015 12:11 PM
chgofirefighter
Apr 18, 2015 08:08 PM
