Timing Belt Tensioner Spring Failure
Old Apr 11, 2011
erict's Avatar
ET
erict is an unknown quantity at this point
I replaced the timing belt, water pump and tensioner pulley on my 2003 Civic 6 months ago. Two weeks ago the tensioner spring broke. I replaced the spring and it broke in less than a week. Has anyone else had this problem?
Old Apr 11, 2011
MindBomber's Avatar
Live for the Twisties
Re: Timing Belt Tensioner Spring Failure
Someone else posted that this happened to them a couple weeks ago, except the spring broke and started wearing through the timing belt. I'm not sure what the cause might be..
Old Apr 11, 2011
BlueEM2's Avatar
Whachya lookin at?
You HAVE to make sure the spring is installed the right way... If you install it backwards you risk failure.
Old Apr 11, 2011
erict's Avatar
ET
Thanks, both had the rubber boot on the top at the fixed pin.
Old Apr 11, 2011
BlueEM2's Avatar
Whachya lookin at?
Odd... hmm... is the actual tensioner torqued properly?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
sharp66
31
Jun 12, 2022 08:45 AM
mattdoc
Mar 14, 2017 12:10 PM
dosmastr
May 5, 2015 12:19 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
