03 ima refuses to work
Old Apr 22, 2020
ChrisBow Pilot's Avatar
ChrisBow Pilot is an unknown quantity at this point
I am pretty sure that the battery on my 03 civic is on it's last leg. The light comes on, but it still works and helps a little bit. I decided to pull it apart and check for bad cells, basically checking to see if I could change a few cells and get a little more out of it. All cells were more than 8v and looked ok. Since I don't have the equipment to deep cycle it, I decided to put it back in. Now, I have 165 volts at the terminals when I turn the key on, but it immediately turns off and the ima light is always on. I pulled it out again and double checked to make sure that I had everything together right and didn't find anything. Any help to fix this is appreciated! BTW the car is not worth much, so I won't be dumping much into it.
richie B
May 12, 2011 02:13 PM
DUDEitsMATTx
May 14, 2006 06:42 PM
dj02
South Cali
20
Sep 26, 2003 11:25 PM
Shadow_Saint
Aug 31, 2003 03:00 PM
JoeB16
Sep 24, 2002 01:32 AM
