Custom Gauge problem
Old Mar 31, 2009
CndyBluCivic's Avatar
CndyBluCivic is an unknown quantity at this point
Ok to start i have a 2002 civic ex and i installed an after market gauge cluster that i bought on www.speedhut.com (white face/blue numbers) and when i installed it the speedometer doesn't work nor does the fuel meter....Can anyone help me with this issue please??
Old Apr 8, 2009
boostnut87's Avatar
boostnut87 is an unknown quantity at this point
Re: Custom Gauge problem
are u adding guages faces or actual cluster? if ur adding just the faces, which i have added on many vehicles, u need 2 check to see if the face is poping up bcuz if so itd stop the needle in its path....simple fix...super glue the back of the face and make sure it sicks sm,oothly to the stock face....if ur adding a whole aftermarket cluster then check the plugs 2 make sure u have signal....
brian257
Jun 4, 2015 08:17 PM
werdnahall
May 17, 2015 11:37 AM
tylerginevan
Apr 27, 2015 12:29 PM
SOHCScreamer
Dec 21, 2001 10:10 PM
SneakerPimp
Nov 8, 2001 02:09 PM
