Electronics Post your questions about Electronics problems here!
Reset TPMS
Old Dec 17, 2023
slowpoke47's Avatar
slowpoke47 is an unknown quantity at this point
Reset TPMS
New member here- need helpful advice! Have 2019 Civic Sport sedan with auto trans and keyless start-stop button. TPMS warning on after tire rotation by local shop. Just checked all tires, pressure as per specs. Have 669 page (!) owner's manual that has instructions on resetting this warning but cannot kill the warning. Two relevant pages from said manual attached. Can someone who has actually done this explain it to me?
Old Dec 17, 2023
Re: Reset TPMS
Choose calibrate on the head unit, drive around for a half hour, maintaining speed between 30-65mph. What I did was hit the calibration button at the stoplight waiting to get onto the freeway (when cross traffic light turned yellow), then drove that for a half hour, in the right lane, just under the 65mph speed limit
Old Dec 18, 2023
123Krash's Avatar
123Krash is an unknown quantity at this point
Re: Reset TPMS
HAve a 2020 Accord, and recently had similar experience.. car indaeler oil change and tire rotation.. pick up car Tire warning.. turn around, back to service drive thru.
Dude comes out and says it has to be calibrated, ok so do it, and why was it done by the tech..
He aired up the rires and said when they rotate they do not check pressure unless you get the tire balanced, then he said every time you rotate or air up a tire you need to re-calibrate the system.. used the HU method, dorve a few and the Pressure warning came back.. recalibrated at a stop light drove a bit and it went out and did not come back.
jjaayy
Feb 26, 2018 08:58 PM
crimson_pearl
Dec 10, 2014 06:36 PM
Timbogates
Sep 13, 2014 07:55 PM
playa6tnine
Sep 29, 2004 12:10 AM
