Help!!!! new trans axle seal failed
Rep Power: 0 Help!!!! new trans axle seal failed
help!!!! so i have had a passenger side fluid leak from the transmission where it meets the axle. i decided to have the mechanic change it because it was only 125. thinking it would be an easy fix and it was something i have never done myself. so i picked it up and drove 45 min home. when i got home the leak was way worse than when i took it in. i took it back to the shop and he is going to take a look. but i get the feeling this is going to be an on going nightmare. its an 89 civic wagovan. the previous owner had it raised. any advice would be appreciated. thanks
Rep Power: 78 Re: Help!!!! new trans axle seal failed
did he replace the axle seal as well? i would have, and you need to find out. if so, and it leaks, a lot of axles are remanufactured and are therefore cut slightly undersize. they make repair sleeves to cure this, but it takes a brain to figure out exactly what sleeve needs to be ordered. this guy replaced the axle 5x before figuring this out, and the sleeve fixed it permanently. you can see an example here. http://www.ptcruiserlinks.com/forum/...tml#post499474
i have all the photobucket link fixes installed, so i've attached a screenshot just in case the picture does not load for you (:
Dr Krieger of Modification
he probably just pushed the seal too far in, or left it hanging out too much.both could result in leaking and damaging the seal.
Replacing the seal and having it sit flush as it should, should stop the leak.
Rep Power: 0 Re: Help!!!! new trans axle seal failed
Yup. I believe that's what he did. Got the car back yesterday and drove about 50 miles with no leaks. So far so good. I apreapprec the reply's.
Xkillswitch56X
12-07-2012 09:37 AM
thisguy
08-09-2011 02:49 PM
RonJ
05-27-2010 12:50 PM
