Help with angeleyes
Okay, i might sound like an idiot, but how do i install these lights? apparently there is two lose wires, one red and one white. where do i hook them to? and which one of those circles is my drivng light? so confused
Hey stp1, a little help?
the middle one is ur low beam's and the one that is exposed near to the center of the car is ur high beams
the 2 wires one red and white are for ur halo's u can splice one of the wires and reconnect them to ur low beam's and take the white wire and connect it to a place in the car to ground it.
u dont have to connect them cuz i havent .. waste of my time and its a big hassle...its not even bright at all so dont bother but unless u are a perfectionist then go for it. its very easy.
there 4 bolts holding the headlights in the car. hehe good luck
okay thanks alot man, but humm when i connect them the highbeam(driving light) doesn't turn on, only the middle one turns on. i wonder if its burned out or something???
oh never mind, i'm so stupid. the centre one is the normal/driving light, always thoungh the one on the left was. Dame the light is so dim, it doesn't look like driving lights. when i put th highbeam on it looks better
Originally posted by O1Coupe
I warned you about the dimmness! Now you need to buy fogs to compliment it and make up for the loss of light...
Yes i know but its so hard to resist on not buying them cuz its only 150 and comes with a pair of painted eyelids. now i need to know how to hook up the blue ring, i tried but i blew the fuse???
TYC and ANGEL eyes are the same .. TYC doesnt have a brighter setting ur both using H1's and its filtered thats why its so dim.
projector's are good if u plan to upgrade to HID that way the light beam is concentrated. u can always grab audi,bmw, benz, etc projector's to retro fit them into them and upgrade to HID if u dont want to shave the hole to fit the H-I-D H1 bulb!
