Neuspeed Springs
Old Apr 30, 2003
JH's Avatar
JH
JH is an unknown quantity at this point
Neuspeed Springs
Well, I just put my new springs on but it doesn't look right. The back looks a little high. Did anyone have this problem when the springs were first put on? I have the Neuspeed Sports. If anyone can help.....
Old Apr 30, 2003
SpoonSi's Avatar
SpoonSi is an unknown quantity at this point
they might be progressive, and need to settle a bit...
i dunno...???
Old Apr 30, 2003
Popkorn's Avatar
Popkorn should not be trusted
Neuspeed Sports are 1.75" in the front and 1.5" in the rear, the back is supposed to be a bit higher.
Old Apr 30, 2003
BJAI's Avatar
BJAI is an unknown quantity at this point
both neuspeed sport and race on coupes are the back is higher than the front......
in the other case for sedan..... the sport is also higher in the back..
but for the race spring the back is lower than the front...
Old Apr 30, 2003
R2FRESH's Avatar
R2FRESH is an unknown quantity at this point
same problem here, but i am not complaining, give it a lil time to set and if that doesnt work drop in a few bricks to way it down
Old Apr 30, 2003
R1Style's Avatar
Yeah... once they settle the drop should be even. APRboy's got Neuspeed's on his ride and his drop would probably be even if he didn't have 1008779lbs subs. My neighbours also has them and his drop looks good.
Old Apr 30, 2003
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
I have Neuspeed Sport and the drop should be 1.75 all around... If you got the Race, the back should be a bit higher, and that's how you should want it to be...
Old Apr 30, 2003
dbzcivic's Avatar
dbzcivic is an unknown quantity at this point
well what the hell are mine then i haev neuspeed sport and my rear is 2.5 and front is 2.25
Old Apr 30, 2003
iamfob's Avatar
iamfob is an unknown quantity at this point
i have sport on my sedan and the front and back looks even
sickkkkkkkkk and loving it
Old Apr 30, 2003
Popkorn's Avatar
??? What car do you have?
Old Apr 30, 2003
Blkcivic's Avatar
Mine is high at the rear too, kidda **** me off cause i've spend money to lower the car not look the same as stock. meh, but i don't have neuspeed
Old May 1, 2003
dbzcivic's Avatar
obviously it is the same exact car.
Old May 1, 2003
BJAI's Avatar
it's can't be that low...if yours is sport......
Old May 1, 2003
iamfob's Avatar
if u cut the springs then it will be a little lowered...ask BJAI for more info
if u want the lowest possible look then get coilover and slammed that bitch down
Old May 1, 2003
BJAI's Avatar
ya, but i don't recondmend anyone to cut their spring....
if just a little it's ok..... like those dead coil..... it's ok....
Old May 1, 2003
XxJDMCivicxX's Avatar
Sport is 1.75" front and 1.5" in the back, Neuspeed Race is 2.25" front and 2.0" back check neuspeed.com if you don't beleive me. Sport Springs are colored Red (positive) and Race should be Black I think.
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
