7th generation Civic's full potential.
Old Apr 19, 2003
Swift's Avatar
Swift is an unknown quantity at this point
What would the absolute full HP/TQ potential of a 7th generation Civic be if modded to the max using natural aspiration? (And without doing insane things such as removing the back seats so it's lighter).
Old Apr 19, 2003
netcbc's Avatar
netcbc is an unknown quantity at this point
Try searching this guy went all out with tuning and port polishing and so on, he is even sell the package he did to his car
Old Apr 19, 2003
cosmicjim's Avatar
cosmicjim is an unknown quantity at this point
dont buy the civic if you want to mod for HP ... the 1.7 ain't gonna be much without a turbo or something incredible
Old Apr 19, 2003
Swift's Avatar
1.7 isn't that bad is it? :P Didn't it go up from 1.6 from the last generation?
Old Apr 19, 2003
AzimuthX's Avatar
AzimuthX is an unknown quantity at this point
This is really hard to answer, if you have $, you can do anything.
For Example
Cams, Pistons, Valves, Boring Out Block, Throttle Body, ETC.
For that amount of money, it would be worth getting a swap.
Old Apr 20, 2003
cosmicjim's Avatar
yes it did go up from 1.6 .... but the 1.6 didn't produce much power either.
Old Apr 20, 2003
Chigga's Avatar
Chigga is an unknown quantity at this point
what are u talkin about??
1.6L made tons of HP......
dont forget the SIR "G"
160HP b16a2 has alot of potential!
especially for road racing......
dont doubt the 1.7L
if HONDA was smart. they would of made it, and i bet with the hatchback they made with the new SIR, are not producing as much sales as the original coupe...
i talked to the guy at brantford HONDA anf HONDA will come back with a stronger equipped coupe!! b/c u, I and all of HONDA knows the coupe sir was the best seller!
dont doubt the 1.7L
just like someone posted..... if u have money do it up!!!
and redvic claimed 219WHP in a 1.7L non vtec motor turboed!
is that good??? and for a light *** car!!! espect to blow doors off mustangs!
Old Apr 20, 2003
cosmicjim's Avatar
im assuming he's talking about a D16 and not the B as his sig talks about buying a '03 Si.
furthermore, he's question talks about wanting to be N/A ... and my comment was simply that not a lot of HP is to be gained with the usual mods ... unless something spectacular is done to the engine, the HP ain't moving up much
Old Apr 20, 2003
Booohahaha's Avatar
BAD MON
yow yow
dont listen to these guys hahaha jk jk
if u gonna get a 7thgen to chill and drive around. then its pretty good for the amount they are asking and it looks pretty decent too.
u can always swap the engine if u want? ... turboing ... hehe.. <--lots of stress on the engine.. N/A all the way !!!!
i doubt honda will ever change the hatch into a coupe in the form of the new siR
maybe in da 8th gen...
Old Apr 20, 2003
Swift's Avatar
hehehe, I want to get my future Civic up to 180HP without a turbo/supercharger. I'm going to probably do the intake/header/exhaust thing first, then learn about what else I can do.
Old Apr 20, 2003
iamfob's Avatar
iamfob is an unknown quantity at this point
bolt on mods and get 180HP? keep dreaming lease: lease: lease:
ask FO, Cue2K1, Andoy, TTCivic, BJai, Stillmatik23, netcbc, bluelle, stunna, cuz they all got the stuffs u listed above done and i dont think they are at the 180HP range
on turbo car, bolt on mods can jack HP up easy but NA car it is hard man
Old Apr 20, 2003
Popkorn's Avatar
Popkorn should not be trusted
If you're going to mod a car to the max (especially performance wise), why are you buying a new car for that purpose?
Just buy a used car, do a swap, and start building your engine to whatever you want.
Old Apr 20, 2003
Booohahaha's Avatar
BAD MON
true but alot of ppl love the new design..and i think its the fact that when u get a new car, specially like a civic where everyone thinks that it is not fast cuz no one will swap a new engine in with warranty and all.
but when some one does in fact do it.. everyone just goes
Old Apr 20, 2003
REDVIC's Avatar
One of few in the 13's
REDVIC is an unknown quantity at this point
Tis possible don't give up hope brotha! Here is a set-up that will get you pretty damn near 180Whp...
-Intake
-Header
-Exhaust
-Pulleys
-High compression pistions
-Agressive Cam
-Intake manifold
-Port polish
-Greddy e-manage
And if you want to bore out the block while your changing pistons... You can achieve more Hp... Displacement=Hp...
I was planning to do my car All motor before I did my turbo set-up... My goal is to run low 1/4 mile times so I had to do forced induction. When you are building a N/a motor you need to maximize air flow and and what most people forget about N/A motors have to be tuned in order to get decent numbers... Fuel and ignition timing are key taking care of this would be the greddy e-manage. Best bang for the buck piggy-back system! And if you have V-tec you can mess around with that and you can always raise the rev limiter for additional high end Hp numbers...
Old Apr 20, 2003
O1Coupe's Avatar
O1Coupe is an unknown quantity at this point
Isn't raising the rev limiter more stress to the engine?
Old Apr 20, 2003
AzimuthX's Avatar
Like the K20A2 RSX 'S in a EP
Old Apr 20, 2003
MSoft's Avatar
MSoft is an unknown quantity at this point
Yup, thank you Honda for using a D17 instead of a B16... ****heads.
Old Apr 20, 2003
O1Coupe's Avatar
The best thing to do, is wait for the new Civic.. I have a fishy feeling a 2.0L is going to replace our underpowered 1.7L..
And SiR will be dropped.. just like Acura CL, and past Prelude... due to poor sales.
But Type-R will be in place of it.
That's my prediction anyway.
Old Apr 20, 2003
Swift's Avatar
What is this B16, D17 stuff anyway? *NOooooooob question*
Thx for those tips RedVic.
Old Apr 20, 2003
Booohahaha's Avatar
BAD MON
D <--- SOHC
B<---- DOHC
K <----DOHC
B + K > D
get my point?
Old Apr 20, 2003
Blkcivic's Avatar
Its like our school grades, A is the best,D is the worst
Old Apr 20, 2003
Popkorn's Avatar
For the price of a TYPE-S swap into a 7th gen civic, couldn't you have easily gotten an RSX TYPE-S? And plus you also get the warranty, and plus all the extra features that the TYPE-S has.
Old Apr 20, 2003
Chigga's Avatar
i believe the TYPE S is way more heavier then our POP CAN CIVIC's
Old Apr 20, 2003
AzimuthX's Avatar
Thats true , but than thats all about modifying
BLKCIVIC ur analogy is incorrect, H and K are the best
Old Apr 20, 2003
Bogus1's Avatar
Bogus1 is an unknown quantity at this point
originally posed by AzimuthX
S2000 Engine
naturally aspired 2.0L 16-Valve DOHC VTEC (engine code F20C)
Old Apr 20, 2003
Bogus1's Avatar
About the Honda S2000 F20C
Production: first year 1999, handcraft
Spec: 240hp@8300 153lb/ft@7500 torque
Engine: naturally aspired 2.0L 16-Valve DOHC VTEC (engine code F20C)
Redline: 9000 RPM
Chassis: High X-Bone Frame 4-Wheel Independent Double-Wishbone Suspension with Coil Springs (chassis code AP1)
Drive train : Front Engine Mount / Rear Wheel Drive System
Transmission: 6-Speed Manual with LSD
Old Apr 20, 2003
Swift's Avatar
D <--- SOHC
B<---- DOHC
K <----DOHC
B + K > D
get my point?
Does B = K?
Thanks for the info!
Old Apr 20, 2003
Blkcivic's Avatar
Does B = K?
No but U = L
Old Apr 20, 2003
AzimuthX's Avatar
I think the H22A is the best because its a powerful engine and easily installed through various generations.
H22A
200hp @ 6800
161 lb-ft @ 5500
B18C5
210hp @ 8000
134 lb-ft @ 7500
The B18 makes more horsepower than the H22A but than its at 8000rpm instead of 6800, but the H22A makes a lot more torque and earlier than the B18C5.
Old Apr 20, 2003
GuSTo's Avatar
GuSTo is an unknown quantity at this point
why do you say the h22a is the best?
