info/help: rsx sway bars
hey FO, if you already have the oem one on there, jsut go to acura and pick a new one up. it's like 150 with bushings and bar and the install literally take 20 mins (including jacking and lowering)..... only issues that might arise is the pain in removing the nuts at the endlinks.....
did you do it too?
who can install this for me... for free
and we'll share some buds or beer
go to Alex and he will install for u cheap
i know a shop that sells teh JDM DC5 rear sway bar (22mm) for $150 new in scarborough
the type S is 19mm and the base and premium is around 17mm
it will be the biggest and best bang for the buck type of mod FO so i suggest u get that then save up for shocks afterward
pretty scare better off with the 19mm bar!!
yes you can ... it'll be about $140 ... more if you need new bolts and such.
as for the install ... im sure most have told you its a 20min job ... just make sure you get get the orientation right, the bar is not symmetrical
Yeah, don't go too thick on the bar. It'll cause some serious oversteer and could rip your subframe. For the older gen Civic's a company called Beak's makes reinforced plates for the D-braket for the ITR bars, but I doubt they make anything for your cars yet.
Alex's shop is located in
114 Sinnott Road, unit#15
Scarborough
416-750-4015
the shop that sells the JDM DC5 rear sway is Defcon but u have to go thru illmatic from this board cuz he works there and he can get u a deal on them. So PM illmatic or call DefCon and see if u can get it for $150 without hookup.
416-803-3589
Scarborough
416-750-4015
416-803-3589
there's been probs with ppl show have the 22mm bars (progress/type r)..... the problems were not with the subframe as long as you got a good tie bar, but the prob was with the endlinks snapping.... our stock endlinks look like a tooth pick!.... if you do go with the 22mm, i woudl suggest getting the progress endlink kit too..... then like boo said, you'll probably need all the stuff on top too... like a rear upper strut etc.......
FO: yupyup, i got the 19mm on and it's done wonders to handling.... i actually got a shop to install it for me while i was getting an oil change. but if you want, we could meet up and tackle the install together..... it was really simple......
i think driftR did something like what u are saying coupestylz, but u have be really careful when u drill cuz one side of the car bar is near the gas tank. other than that its just drill and install =)
if you don't have an oem one, i would suggest getting the whole progress setup.... the progress sway comes with a beefy tie bar.... and since you don't have the oem one, you'll aslo need the endlink kit too..... but with that all said and done, the car should handle amazingly.... you'll definitely feel a major diff...........
Gusto: when u selling your RSX 19mm bar?
my car has no sway bar when i bought it so i need 1 badly, i already have all the strut bars and tie bar but it doenst do **** without sway bar
