Canadians with HID, disabling daytime running lights?
Old Apr 2, 2003
klam's Avatar
klam is an unknown quantity at this point
Anybody here installed HID? How did you disable daytime running lights?
Old Apr 2, 2003
SumAzunGuy's Avatar
SumAzunGuy is an unknown quantity at this point
i believe when yoju install hid the DRL will be disabled
Old Apr 2, 2003
iamfob's Avatar
iamfob is an unknown quantity at this point
if u get the H4 kit (low beam) then u wont have high beam so ther'es no daytime running light for sure
but if u get the H4 HID kit with high low beam then u have to do something to make it stop functioning. (i think take one fuse out from the fuse box)
ask Gusto, he has HID on his car and he should know more than me
Old Apr 2, 2003
GaGu's Avatar
GaGu is an unknown quantity at this point
there 2 DRL fuses u have to take out from under the dash..
forgot which ones..look in da manual its listed there
Old Apr 3, 2003
netcbc's Avatar
netcbc is an unknown quantity at this point
Yeah right you can take out the fuses? I thought you would have to unplug something from behind the gauge cluster, i'll have to check it out
Old Apr 4, 2003
GuSTo's Avatar
GuSTo is an unknown quantity at this point
pull out the fuse from under the dash...just look on the panel and make sure you pull out the right one!
Old Apr 6, 2003
klam's Avatar
Cool, thanks, I'll check under the dash. I'm considering the Catz H4 dual beam kit.
Old Apr 6, 2003
iamfob's Avatar
how much for the Catz kit? i heard so many good things about them from ClubSi.
Old Apr 10, 2003
klam's Avatar
Check out Liteswap.com , ask for the 7thgencivic.com discount of 10%.
Old Apr 17, 2003
magnetic1's Avatar
magnetic1 is an unknown quantity at this point
No need to ask Just use the coupon code "civic7"
Old May 6, 2003
Staticfree's Avatar
Staticfree is an unknown quantity at this point
wait, don't we require drl? i tot that all new cars had to have them?
Old May 6, 2003
1llmatic's Avatar
1llmatic will become famous soon enough
there's one fuse in the dash you need to pull out then ur done.
Old May 21, 2003
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
The only problem with pulling the fuse is that the "DRL" light will come on and stay on. I am looking to figure out how to stop this other than cutting the wire in the gauge cluster.
Crashoveride
Old May 21, 2003
Popkorn's Avatar
Popkorn should not be trusted
Crashoveride
There are 2 fuses! If you just pull just the one the DRL light will come on and stay on. You gotta pull both.
Old May 23, 2003
tekgnosis's Avatar
Ask me about your mom.
ok, what if I want my halo's on (attached to DRL), but I don't want my DRL lights on?
should I just disconnect the wires to it? is there any easy way around this?
if I take out the DRL fuses, the DRL will not go on, but then neither will my halos. I'm under the assumption that they'll operate the same way that the stock lights do, when the DRL are on, the beams on the H4's were pretty dim, but on nonetheless...
CarStuff
Dec 6, 2020 12:52 PM
werdnahall
May 17, 2015 11:37 AM
eorlando1
May 17, 2015 11:16 AM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
cazminn
Nov 9, 2001 11:18 AM
