Installing Ground Wires
Old Jan 10, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
I did the battery to engine, engine to chassie, but i cant find any other stock ground wires, or do I ADD the ground wires to tranny and amp??anybody who have hyper ground wire pls help!!!thanx[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 10, 2003
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
you brought the ground wire...? how mcuh
Old Jan 10, 2003
R1Style's Avatar
You're not only replacing the ground wire that exists but you're also adding wire that isn't there.
There are 5 ground points you need. I believe this is what you're supposed to ground:
1) From battery (-) to passenger side chassis
2) From battery (-) to engine
3) From transmission to the engine (same point as above)
4) From engine (still the same point) to motor mount (drivers side)
5) From motor mount (same point as above) to drivers side chassis
Essentially what you're trying to do is ground the car from left to right.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
dinsum
May 28, 2015 09:30 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
blackbullet
Dec 1, 2001 03:44 PM
