Need some help here
Old Aug 18, 2002
XxJDMCivicxX's Avatar
Need some help here
I replaced my stock lights with H4 plazma/xenon lights, i think the wire came out which connects to the light, one of them is out its the one on the right. When I installed them it was a pain to install because there is less space. Should i just take off the front bumper and take out the headlight (referring to the DIY) and see if the wire is disconnected cuz it doesnt seem to be but I can't take off the rubber piece protecting the light I can't reach it
Old Aug 18, 2002
2K1SiCDN's Avatar
2K1SiCDN is an unknown quantity at this point
There should be ample room to change the bulbs, I know there's less room on the driver's side but all you need to do is lift up the resevoir that's there, it's all in the manual. Anyways for the rubber piece there should be tabs on the top and bottom that help you take it off, look closely and you'll see it. I don't think you need to remove the bumper to fix this problem, but I'm not sure how bad it is.
Old Aug 19, 2002
supYO's Avatar
supYO is an unknown quantity at this point
got big hands eh?
there should be enough room though
but taking off the bumper and housings makes it easier to change the bulbs
but the process takes LONG
Old Aug 19, 2002
MSoft's Avatar
MSoft is an unknown quantity at this point
Quote
[hr]Originally posted by: 2K1SiCDN
There should be ample room to change the bulbs, I know there's less room on the driver's side but all you need to do is lift up the resevoir that's there, it's all in the manual. Anyways for the rubber piece there should be tabs on the top and bottom that help you take it off, look closely and you'll see it. I don't think you need to remove the bumper to fix this problem, but I'm not sure how bad it is.[hr]
Yup, it's all in the manual. I was noob at car stuff but I still managed to change bulbs without issue.
Old Aug 19, 2002
thnxs for the advice on the reservior i hope it gives me the extra added room... Thnxs for the replies
Old Aug 19, 2002
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
you changing the headlights?? Why don't you do it from behind the fender wall? Turn the steering wheel all the way to the rigth if you have to change the left bulb, and vice versa. No need to remove the bumper.
