HONDA-MASSIVE-B-Series-EF-Turbo-Civic-PART-OUT
Old Feb 13, 2010
SHortHand's Avatar
SHortHand is an unknown quantity at this point
LINk WITH PITURES:
http://toronto.kijiji.ca/c-cars-vehi...AdIdZ185745576
I just had a front end collision.... Rad, Drivers Fender, Front Bumper. All toast. THe rest is ok. Motor ran perfectly fine after collision. No Damage to it. ASK if you want to package an Item or two.
MAKE me any REASONABLE offer !
Car 1989 Civic Si - B16a2
1. B16a2 Motor + GSR Cable Tranny (Have Bill for tranny) + ITR Clutch/Flywheel.
-74km on motor
-Only Synthetic Oil + Fram Syn Guard Filters used.
-Tranny was good before the accident, shifted threw all gears with ease.
-ITR Clutch + Flywheel (less then 15,000km on them)
-Includes New Distro King Distributer, New Wires, New NGK Platinum Plugs, -Fuel Rail With B/M Adjustable Regulator. (TB & Intake Mani NOT included.. But we can work something out).
-Includes Axls/Shafts
-Alt
(Extra Items)
-Complete/BONUS ECU PW0, Wiring Harness, HAS SPort MOunts, Integra Type R throttle body on port matched 2000 SiR intake mani. + either an EF9 AIr Intake Box with a JDM Green Filter. OR Plished Ractive Air Intake.
Asking $1600
OR
Complete/BONUS $2000
2. EF Factory Si Buckets (Front)
-Good TO Mint.
-Single tear on drivers
-Comes with extra Skins/ Fabric
-Rails fully working
-Clean backs. No stains of foul odours/ Non smoker.
-HARD to find.
Asking $ 260. (Low ballers will be ignored)
3. EF9 Rear Seats (Rare with head rests).
-Fantastic shape.
-Rare hard to find part. Perfect for the EF9 Replica project !
Asking $400
(OR BUY THEM TOGETHER and I WILL package them.)
4. EF9/European VTi/SiR Guage Cluster (Rare)
-ODO Reads 243km
-Revs go to 9500+
-250km/hr SPeedo
-All back lights are perfectly functional
-zero scuffs.
Asking $200
5. Tekno Front, Rear Strut Bars. REAR Lower Control Arm Brace, Megan Harness Bar (GUn Metal Finish)
-Good Shape All around. Polished Finished. (Except Harness bar which is Gun Metal Colour)
Asking $170 For All of them.
6. EF EQ Centre Console
-8.5/10 COndition
-Very Little scuffing. )Considering they are 21+ years old !)
-Will be hard pressed to find it in better condition.
-Includes whole centre console, boot + HVAC Piece. + Cage
-No Radio. Sorry !
Asking $200
7. Complete Suspension (Tokico, Ground COntrol, SPC)
Ground Control coilover springs (F400 R300)
Tokico Illumina adjustable shocks
Ground Control aluminum front shock extenders
Energy Suspension bushings Master Kit
Prothane rear compensator arm bushings
Energy Suspension rear trailing arm bushing
SPC adjustable front upper ball joint
SPC rear adj.
Will include Arms
Asking $700 for it all.
8. 15" BBS Multi Spoke Rims + Falken 915 Tires
-Falken 915's (225,55,R15)
-All Season/Performance. VERY comfy tire, yet incredible handling.
-Rear Passenger Tire has Sidewall Damage. Tire Shop said it was fine/ Passed Safety with it.
-Rims Black Finish, WIth Lip. (Could use some repainting.)
-Rear tires are 90 % + Tread.
-Front tires are 70 %+ Tread.
Asking $450
9. Integra Type R throttle body on port matched 2000 SiR intake Manifold.
-Good shape.
Asking $200 Firm.
10. Spoon JDM "Jasma Approved" Exaust Manifold/Header + A’Pexi World Sport II cat back exaust
- (4-2-1) with 2 oxygen sensors for PWO ECU.
- Exaust Leaks after the resonator. Will require New piece of pipe installed. (Zoro Muffler Quoted me $100 Dollars installed for 2.5" crush bend piece installed, or $200 for a mandrel bend piece installed.)
-BRAND new Rear muffler & Piping. Sounds fantastic !, No Rice !
-Finish on the Header is still decent. No Leaks.
Asking $240
11. Auto Meter Fuel Pressure and Oil Pressure gauges (Pro Comp Ultra Lite Series)
- Oil Guage has slight ding on bottum
-Includes NEW Sensor/ Piece for Oil Guage
Asking $80
12. Complete BRAKE upgrade REAR DISC, FRONT GSR Calipers. (EF, EG, EK !)
-Goodridge Stainless Steel lines front
-’91 CRX Rear JDM Knuckle / Disc Brake
-’93 GSR front calipers with Hawk HPS brake pads
-Custom Northern Motorsports brake lines in the rear
-Rear ’91 CRX disc brake conversion
-RacingBrake cross drilled and slotted rotors front and back
-89 Prelude Master cylinder 15/16" from Honda
-ROtors & Pads are still good.
-Does not include Hubs. (but will include EVERY THING you NEED to install on your Civic.)
-Rear Lines will be slightly different on EG/EK.)
Asking $600
13. Interior/Exterior Bits
-Power mirrors + Interior Switch (1990 civic LX) $60 (MIrrors got really slow in the winter...)
-Door Handles (Key Fob Less) (rear 1990 Civic LX) (power lock needed) $40
-EF 88-89 Indented Side Trim $20
-Rear Hatch Glass $60
-Rear 88-89/ZC Sedan Bumber $120
-Passenger Headlight (Condensation in it, 6.5/10) $20
-Complete Rear Tail/Centre Light Setup (Civic shaved off back light) $120
-Rear Seat Glass WIth Openers $40 Both. OR $30 Each
-Honda EF EQ Upper Dash (NO Radio/HVAC) Includes clock 9/10 $60
-Front Lower Turns Signals $20
-EF Front Lip (Modified Accord Lip Fits EF) $40
-EF SI Steering Wheel(Has Factory Leather Wrap on it..BUT it is kinda rough) $40
-Rear Privacy/Hatch Cover 9.5/10 $100 FIRM
-Anything Else such as interior bits, please JUST PM me or Email.
14. Engine/Under Hood Bit
-Interstate Slim Battery + tie down (Little over a year old) $40
-Cusco High Pressure Rad Cap $30
-Rad Fan $20
-EF9 Stock Air Intake(With JDM Green Filter) $60
-Polished Ractive EF Intake (will fit D or B Series) $30
15. HAS SPORT EF B-Series Cable Swap Mounts
-Good Shape. No Damage.
Asking $240
16. Moroso Oil Catch Can Setup.
-Dirty. But is in perfect condition. JUST needs a cleaning !
Asking $60
17. COMPLETE EF Exterior Panels
-BRAND NEW OEM FENDERS (Still in casing)
-BRAND NEW Rocker Panels COMPLETE from the bottum up into the door sill.
-BRAND NEW OEM Rear Quarter Panels
-Restore your Rusty EF !!!!
-Asking $440 (The Rockers alone cost that much new !)
18. Johnny Race Car Extruded Tube Core Intercooler
-30ish to 36" x 8 x 2.5"
-Extruded Tube Core
Asking $120
19. DSM BOV
-Has pipe piece still attached.
-Good working order.
Asking $20 FIRM
PM Me OR Email me @ mgmediasolutions@gmail.com (use CIVIC PARTS in the title.)
I can not meet you. I have no car ! I am located in Bolton Ontario. Just 10 minutes North of Woodbridge/Toronto & 15 minutes NOrth East of Brampton.
FIRST COME FIRST SERVE. I start Pulling everything on the 13th. I will not hold anything unless you make a deposit on the part. Ill get back to everyone as fast as I can !
Old Mar 5, 2013
Verdo909's Avatar
Verdo909 is an unknown quantity at this point
Re: HONDA-MASSIVE-B-Series-EF-Turbo-Civic-PART-OUT
Hey I Got A Question..? What would you recommend me for starting to modify my 1990 Honda Civic LX fully stock. I want to put it on a high performance what would you suggest I begin adding
