Advice on 4 quality struts -(new).
Old Jan 8, 2008
chucknibbs's Avatar
chucknibbs is an unknown quantity at this point
Would you guys recommend a place online in canada were I can buy 4 new struts? I currently have 4 koni yellows that were on my 2003 civic si when I purchased it a few months ago, but now im getting tired of the hard bumpy ride , and swerving to avoid every bump on the road. Im looking for your advice on 4 struts that are good quality, and that offer a good smooth ride.
Old Jan 9, 2008
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
Re: Advice on 4 quality struts -(new).
koni's are the best, keep them
Old Jan 9, 2008
rjngo's Avatar
rjngo will become famous soon enoughrjngo will become famous soon enough
he doesn't like the stiffness anymore, i think he wants some oem one's or close to oem specs
Old Jan 9, 2008
Civic_JDM's Avatar
Civic_JDM is an unknown quantity at this point
u can adjust the stiffness of the struts for koni yellow....i used on my 01 civic for 4 years and i think they're the best....so if i was u i will keep it....
Old Jan 9, 2008
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
Obviously he's not happy with the koni's. Telling him to keep the koni's is like buying someone something YOU want for THEIR birthday.
chuck, the issue is that the struts you have are designed to lower and stiffen the ride for better performance and track grip, which pretty much guarantees a reduction in everyday "pillowy" ride comfort. Also, depending on the type of koni's, the shock towers may have been cut to make them fit.
Assuming you've already played with the adjustment on the konis and it still isn't to your liking, if you want a more stock feel you may have to go with a shock and spring combo that is less geared to performance. Shocks and springs come separately and offer a myriad of lowering and ride comfort options, but they don't corner or handle as smartly (in general) as full coilovers.
A good stock replacement for shocks are Tokico HP's. AKA "Tokico Blues" they are pretty close to stock. They don't like more than about a 1" drop so if you are slammed down you might have to consider something else. Then again, if you are more than about 1.5" drop you can't really expect a pillow soft ride anyways. Dezod has them, as do a number of other retailers.
For springs, if you don't want to lower the car I'm sure there are plenty of slightly used stock civic springs for sale. If you want to lower slightly, I would say the Eibach pro-kit is a good bet (lowers approximately 1"). If you want to be slammed lower than that, check the suspension picture post thread for ideas.
Good luck.
Old Jan 10, 2008
chucknibbs's Avatar
Thanks for the advice,and help...
I`m not an expert on car parts, but I`am a little confused now because my wife called around to a few local dealers for prices, and she mentioned that we need 4 struts, but the person on the phone said: You need struts, springs, and a mounting kit. I`m confused? My wife then called around some more, and the person on the phone said : You need springs, shocks, and mounting kit. Now is a strut the same as a shock? What parts does the suspension consist of so I know exactly what to buy? Is it shock, strut, spring, and mounting kit?
Old Jan 10, 2008
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Well if you are looking for something OEM, then what you want is...
2 Front Upper Mounts
2 Front Struts
2 Front Springs
2 Rear Upper Mounts
2 Rear Shocks
2 Rear Springs
Fronts are Struts, rears are shocks.
Old Jan 10, 2008
chucknibbs's Avatar
thanks.
With the 4 koni I have, would that be the same thing as you listed?
Old Jan 11, 2008
Nameless's Avatar
TURTLEonK
Yep!
Old Jan 11, 2008
chucknibbs's Avatar
Good luck.
I want to lower the car to 1 instead of I beleive its currently at 2. If raising it back to 1 helps the ride? then thats what Ill have to do. So the tokico Blues would be my best bet? What springs would go good/match with the blues?
Thanks for your help
Old Jan 12, 2008
reddawnman's Avatar
Coilover struts generally give better performance than a shock / spring combo, but somewhat at the expense of ride comfort.
I think you should take my advice with a grain of salt - I'm on stock equipment right now and can't recommend anything specifically, but I have HEARD that the Tokico blues and eibach's pro-kit springs work nicely together. The tokico's don't do well with a larger drop (more than about 1.5"), and eibach's pro-kit springs only drop about 1".
Your mileage and experiences WILL vary. wait for other posters to chime in. I recommend not from personal experience, but from what other posters have said.
Old Jan 14, 2008
jer2k's Avatar
jer2k is an unknown quantity at this point
I have the Tokico Hp Blue and H&R sport springs (1.3"). The ride quality is simialr to stock. I have nothing bad to say about this combo.
However, i got my springs about 2 years before my Tokicos. If you are going to buy everything at once compare the cost of buying springs and struts/shocks with buying a full coilover setup.
The full coil over set up would also be easier and cheaper to install I would have to think.
Old Jan 14, 2008
reddawnman's Avatar
Allright - Since Iron Eagle is on AMC right now, I'm hijacking this thread...
I'm thinking about the blues and pro-kits myself... Then SpoonEM had his accident and is selling his coilovers. What is better for my needs?
I drive 22K miles a year, and its mostly on the highway. I need ride comfort to be at least close to stock, and I need tire wear to be about what it was stock. Would like to lower 1", maybe get some better rims. I DEFINITELY want to get a progress rear / front sway bar, and I already have a neuspeed upper strut bar.
I need something that keeps the ride comfortable but would love to have some better handling and grip. I don't auto-x, but I wouldn't mind being able to go to qualcomm one weekend and see how many cones I could knock over. What would you buy in my situation, coilovers or the blues/pro-kits?
Oh, and spoonEM, if you are reading this and haven't sold your coilovers.... I'll be PM-ing you if the peanut gallery eggs me on.
end threadjack...
Old Jan 14, 2008
chucknibbs's Avatar
Well, to add to my misery, my right rear shock is blown, and my front left shock is blown. This was according to my mechanic. Since I wasnt the original purchaser of the koni shocks, this makes the warranty void. So now I have no choice then to buy an all new suspension. So so far I have been given the advice to buy Tokiko blues, and h$r springs, and or the eiback kit. So I would like the advice of other members on what would be the ideal setup for me? Im not a racer, and I dont want my car lower then 1 if this will kill the comfort ride. I just dont like to swerve around every bump on the road. I use my car for work, and for cruising here and there. I really would like to get something mid level, or best bang for my dollar. As far as I remember, my mechanic told me that I need a shock, struts, springs, and a mounting kit. I hope this was everything becasue I have to buy my setup in the next few days, and I hope you guys can direct me in the right direction?
Old Jan 23, 2008
Nameless's Avatar
TURTLEonK
Go with KYB GR-2 shocks/struts and oem springs.
Old Feb 3, 2008
vtec_concept's Avatar
vtec_concept is an unknown quantity at this point
From what I read on various civic forums...
Most comfy ride found is the Tein S.tech and Tokico Blues would be
the most affordable and most comfortable ride..
honda.lioness
16
Feb 10, 2017 10:53 PM
Amulon
Aug 18, 2015 11:03 AM
bmwstar98
Aug 16, 2015 02:28 PM
alaga
25
Aug 13, 2015 04:42 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
