Help with manual swap parts!!
Old Jan 31, 2006
Shifty's Avatar
Hey everybody,
im doing a tranny swap this season (finally) and i need help finding some parts. I know that these parts are all available through the dealership but as much as possible im trying to see if i can get it somewhere else since the dealerships down here charge an arm and a leg.
The major things that i need that I dont mind being used are:
-Clutch pedal assembly
-clutch reservior
-clutch hard and soft lines
-uncut si (ex) wiring harness - Check (Linsook)
-Cluster - check (Big)
Ive already called and visited scrapyards around here as well as ebay and so far have been unsuccessful.
Thanks for lookin!!
Old Jan 31, 2006
BIG's Avatar
BIG
guy....do you want my cluster? I'll help you with this
Old Jan 31, 2006
linsook's Avatar
linsook is an unknown quantity at this point
i have a si ecu and wireharness lmk if your interested
Old Jan 31, 2006
Shifty's Avatar
lol...pm'd ya big guy.
Old Jan 31, 2006
Shifty's Avatar
pm'd
Old Feb 1, 2006
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
isnt there like a site that lists all the wreckers in north america and you can search for specific parts in your area? i've seen it before but cant remember the site name.
Old Feb 1, 2006
1llmatic's Avatar
1llmatic will become famous soon enough
remember u need a brake pedal too
Old Feb 1, 2006
Shifty's Avatar
do i really need a new one? I thought i was going to get away with just trimming the pedal to clear the clutch?? or is the brake pedal mechanism totally different from an auto and a manual??
Old Feb 1, 2006
Shifty's Avatar
Ok, so update. Thanks to Big and Linsook, I have my wiring harness and manual cluster!! Thanks boys!!
Bump!!
Old Feb 6, 2006
AznSaint's Avatar
AznSaint is an unknown quantity at this point
I have a stock gear shift box/stick. not sure if you need one of those though
Old Feb 6, 2006
Shifty's Avatar
I already have those, thanks tho!!!
Old Feb 6, 2006
BIG's Avatar
BIG
if all goes well I should have your cluster for you Sunday night when I get back to TO.
Old Feb 8, 2006
Shifty's Avatar
awesome!! thanks bro
Old Feb 10, 2006
KnightX_ae86's Avatar
KnightX_ae86 is an unknown quantity at this point
ask JDM_BB hes done the swap b4.... he'll b able to help
Old Feb 10, 2006
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
Ken I will guide you through haha, leave me a msg on msn if you need help. You know If I can I would` haha
Old Feb 10, 2006
Shifty's Avatar
Thanks Eric, But im not worried about performing the actual swap, its getting the parts to do them and such.
The one thing that I have a question with is with relation to the manual tranny mount......do i need to weld that in place? What did u do? Im getting mixed info about this saying that i need to use a manual subframe. Any help would be greatly appreciated.
Old Feb 12, 2006
jdm_bb's Avatar
What I did about the transmission mount was I weld an extra piece so I could use my original sub frame. Me and civic_jdm both went to the same guy for the swap, and we both had it weld. I would recomended you get the sub frame if you don't like to weld, but It's gonna cost you alot for the frame unless you can find one in the junk yard. Regardless if it's safe to weld on to the frame. I had my swap done 1yr and a half so far the weld piece is still pretty hard, because when ever I do an oil change I check it but It seems fine.
Old Mar 2, 2006
runner1738's Avatar
whats the relative cost of this? and where do you find people to do work like this, also if you use the orignial cluster from an automactic can you just hook up a seperate tach for it?
Old Mar 5, 2006
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
same question except I have a tach, how much does this cost? My left leg gets so bored while driving, I could really use some clutch exercise
cruisers10
May 12, 2015 10:46 PM
SoyerOner
May 11, 2015 09:46 PM
davidpaustin
Apr 29, 2015 02:23 PM
green01civic
Apr 29, 2015 01:36 PM
bsmiley
Apr 27, 2015 01:27 PM
