k swap parts questions
i found a list of parts i need for k swap but lots of things hard to find out, but how much rouffly in parts would it cost excluding the hasport stuff,
sorry lol... i ment everything except for the mounts + motor + tranny + ecu maybe this list will clarify
Quantity Description
1 K20A Intermediate Shaft
1 Axles from 02+ Civic Si
1 RSX or 02+ Civic Si Sub Frame
1 Hasport ESK1 Bolt In Mount Kit
1 Hasport ESKWH Conversion Harness
(Available From Hasport Soon)
1 RSX Shifter Assembly & Cables
1 02+ Civic Si Radiator & Fans
(RSX Will Fit With Some Trimming Around Cap Opening In Grill)
(Condenser Fan Assembly Available From Hasport Part # ESCFA $125)
1 02+ Civic Si Upper & Lower Radiator Hoses
1 RSX Throttle Cable
1 RSX Fuel Line
1 RSX Brake Booster Line
1 RSX Purge Line
1 2002+ Civic Si AC Line From Compressor to Condenser
1 RSX Clutch Lines From Master to Slave Cylinder
1 Custom AC Line from Compressor to Condenser
1 90 Accord Negative Battery cable
1 Custom Hood Latch Support
1 RSX High Pressure Power Steering Hose
(If You Want Power Steering)
1 RSX Power Steering Return Line
1 92-95 Civic Power Steering Reservoir With Bracket
1 RSX Fuel Line
1 RSX Purge Line
SoyerOner
May 11, 2015 09:46 PM
davidpaustin
Apr 29, 2015 02:23 PM
cloudguy
Apr 28, 2015 05:02 AM
