ingalls camber kit rust problem?
Old May 1, 2005
infinite's Avatar
infinite is an unknown quantity at this point
Unhappy ingalls camber kit rust problem?
anyone here have the ingalls camber kit on an '01-'03 civic and run it through at least one winter?
the rear control arms on mine have a light coating of surface rust on them and i've only had them on for a year(1 winter). when i compare them to my oem control arms(which went through 2 winters) there is significantly more rust on the ingalls arm. is this supposed to be normal? i spray my car weekly in the winter and i usually wash my car at least once every two weeks in the summer. any feedback will be much appreciated. thanks.
Old May 1, 2005
vicLX's Avatar
<--That really is ME
give the camber arms a brush of soft wire brush and see how bad it is...then spray with a ligth WD40....
I have the SPC carmbers and had a light coat of rust...then i steel wool sanded it and a light spray of WD40 once and a while and its fine
Old May 1, 2005
SiG's Avatar
SiG
If you guys dont mind me asking, how much were your camber kits and whered you get them?
I may need a camber kit in the rear...
Thanks for your help!
Old May 2, 2005
R1Style's Avatar
ya the Ingalls are known to rust so you're not experiencing something new.
You can clean them up the way vicLX just mentioned and once you do that, cake that **** with some grease to prevent it from rusting again.
Old May 2, 2005
vicLX's Avatar
I can get you rear SPC camber ... but i suggest you try to clean them the way I stated above before you spend money on something else you might enjoy... Like a lap dance and beer... or some new blank CD's fo you can burn some new tunes for your car...
Old May 3, 2005
FaZe's Avatar
FaZe is an unknown quantity at this point
how much can you get me the rear SPC for?
Old May 3, 2005
smokedcivic's Avatar
"SLIPSTREAM R"
smokedcivic has a little shameless behaviour in the past
what you could do is also coat the camber arm in some bearing grease or even vaseline...or just plain old rust check spray can will work too...
Old May 3, 2005
7Gnoob's Avatar
7Gnoob is an unknown quantity at this point
How much are rear camber arms? I'm gonna need 2 sets.
Old May 3, 2005
Pharoh's Avatar
Bobaganoosh!
get a can of Krown rust proofing....works wonders.
Old May 3, 2005
SlimmKidd's Avatar
SlimmKidd is an unknown quantity at this point
we should start a Gb on camber kits cause I need them too!!!! Thats 4 people!!!!!
Old May 3, 2005
SiG's Avatar
SiG
Hey VicLX can you tell us how much you can get us camber kits for?
I have someone who can supply us for a GB, hes close to Toronto so getting them here quickly wont be a problem, but he doesnt have the greatest prices. If it comes down to it though, I'll see what he can do as far as pricing goes with him.
Old May 3, 2005
vicLX's Avatar
i'll post up prices tomorrow
Old May 4, 2005
SiG's Avatar
SiG
thanks a lot!
Old May 4, 2005
vicLX's Avatar
from my dood!!
5 or more people
50% non-refundable deposit to confirm your order
Ingalls
Must indicate which year your car is.
01-02
2 x Ingalls Front I-81260 14mm / 2 x Rear 38970
03-05
2 x Ingalls Front I-81280 16mm / 2 x Rear 38970
Price $260 including taxes.
PM me if your intersted.. i'll post the order count
Old May 4, 2005
SiG's Avatar
SiG
Thats just for the rear, right? (Just making sure I havent misunderstood anything here)
Old May 5, 2005
vicLX's Avatar
yup just the rear... i can get you prices for the fron to if need be.. i'll see what I can do if you buy all 4 corners
Old May 6, 2005
cdmx's Avatar
Got mine for $113...ill post a thread about it i have pics of the parts
Old May 6, 2005
vicLX's Avatar
dood your cramping my sale.. LoL
Old May 7, 2005
02ciVike's Avatar
02ciVike is an unknown quantity at this point
I have the ingalls camber kit but have not encountered rust build up. I drove through last winter and the control arms look the same as when they were put on. What did you spray your car with? Do not use WD40 use grease. WD40 is a detergent that will break down grease and ruin the lubrication.
Old May 9, 2005
7Gnoob's Avatar
We should look into a group buy, anyone else
7Gnoob- 2 sets
Old May 10, 2005
jhonsok's Avatar
The blackbeauty ES1.
Yeah, i'm in for that..
I just need one kit for the rear.
jaje
38
May 16, 2009 12:29 AM
ernhole1
Dec 6, 2001 12:05 PM
speed werx
Nov 27, 2001 08:52 AM
andylao
Nov 9, 2001 07:36 PM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
