touch up paint
Old May 15, 2003
NSXiboi's Avatar
NSXiboi is an unknown quantity at this point
Post touch up paint
Hey guys, i used touch up paint on my car and the paint looks different from the original paint. How do i make it blend in perfectly with the original paint?
Old May 15, 2003
wcsjunior's Avatar
Supreme Member!
it will never blend it w/ original paint... especially if ur paint has pearls. its hard to match the touch up to the actual paint job...
Old May 15, 2003
Whitehype02's Avatar
Whitehype02 is an unknown quantity at this point
There is a one step touch up that doesnt require clear. If you have access to an airbrush you could lightly blend it to the original. Use low pressure with a moisture trap. You probably wont get an exact match without a great deal of blending.
Old May 16, 2003
Master's Avatar
Banned by Admin
I had to use touch up paint, some one shot three BBs into the the side of my car and cracked the paint and left three small circles all the way to the metal. So I used the paint so my metal wouldn't rust. It looked the exact same color. I think the touch up paint honda sells is the exact smae paint they use when they are spraying the cars at the factory.
Old May 16, 2003
FALKEN's Avatar
Civicforums Junkie
it will never match the factory paint...that is a huge marketing scam from the manufacturers
Old May 16, 2003
Master's Avatar
Banned by Admin
then how come mine matches perfectly?
Old May 16, 2003
d12d's Avatar
d12d is an unknown quantity at this point
It depends how long you have had your car and how long it has been in the sun. If it is out all the time the paint fades.
Old May 16, 2003
Master's Avatar
Banned by Admin
It is never in a garage and I got it in August 2001
Old May 16, 2003
CivicBR900EX's Avatar
Master
CivicBR900EX is an unknown quantity at this point
Let's see the pic, I don't think so
Old May 16, 2003
Zzyzx's Avatar
Autocross Junky
The only colors that will blend in perfictly are non Metalic colors. With metalic paint, when you brush it on the Metal flakes lay down differently then when the pait was sprayed on, and thats why they look so diferent.
Old May 16, 2003
FALKEN's Avatar
Civicforums Junkie
i would love to see pics of touch-up paint used with a 'perfect' match to oem...
Old May 16, 2003
Master's Avatar
Banned by Admin
k well you guys are gonna have to wait till monday, and I will take a pic of them, I also used the paint on my windshield sprayers, and it is almost perfect but not perfect I will take a pic of them too
Old May 16, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
You can't always match the non-metallic colors either. My old Nissan was white, and the touch up didn't match. Every batch is going to be a little different. Sometimes its more noticable than others. If it bugs you that its nowhere close, then just fill the nicks in with clear primer, but you'll never get the touch up to match. I don't even think the touch up is chemically the same as the original stuff... its something totally different all together.
Old May 16, 2003
FALKEN's Avatar
Civicforums Junkie
im confused......first you said that it matches 'perfectly'...but now that your going to take pictures to show us all...its 'almost perfect'??
Old May 16, 2003
Master's Avatar
Banned by Admin
I am talking about the washer nozzles that had black under them therefore making the paint darker afterwards. I am not talking about the actuall body parts I retouched when I say almost perfect. I was talking about the nozzles. Do you not read the whole thing?
Old May 16, 2003
liquidblue's Avatar
liquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trusted
touch up paint is put into the little bottle from the same mixture they used to paint the car. the method of application will make it look different, along with normal fading from sun/head and other elements. in the beginning it's the exact same paint, but if you've had your car for almost 2 years in the sun every day its going to look very different.
Old May 16, 2003
FALKEN's Avatar
Civicforums Junkie
i was just asking because you confused me...dont start
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Cam Diaz
Sep 28, 2015 08:34 PM
carid
Sep 28, 2015 10:13 AM
speedlever
Sep 24, 2015 07:18 PM
