BHP...what does it mean?
Old May 7, 2003
SOHCScreamer's Avatar
SOHCScreamer is an unknown quantity at this point
when referring to a car's HP rating, what does BHP stand for? i see it mostly describing european cars.
i think i know but i wont say it cuz i dont wanna sound stupid if im wrong.
Old May 7, 2003
LJ's Avatar
LJ
Fernando The Donkey Lover
LJ is an unknown quantity at this point
it means brake horsepower, engine horsepower rating determined by brake dynamometer testing
Old May 7, 2003
wing0's Avatar
wing0 is an unknown quantity at this point
is there a conversion you can do to find out the HP from BHP.
Old May 7, 2003
LJ's Avatar
LJ
Brain fart
Old May 7, 2003
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
Re: BHP...what does it mean?
bhp is the same as whp. Use the same metrics as you would to determine whp. 75-80% for manual transmissions, less for autos.
Old May 7, 2003
yeah but what does it stand for?
Old May 7, 2003
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
RTFT. LJ answered it. For the lazy, it means Break Horse Power
Old May 7, 2003
i meant BRAKE.
what does Brake mean? what is meant by brake dyno mean?
explain for us dumbasses wont you?
thanks so much
Old May 7, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
It almost identical to wheel horsepower... just not measured on the wheels. A dyno wheel has a known force that your wheels have to go against to spin it... that's why it's wheel horsepower. Brake horsepower puts a known force against your driveshaft, which acts like a brake, and the driveshaft has to have a certain power to pull free.
Old May 7, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
Explanation of the principle...
http://inventors.about.com/gi/dynami...ronybrake.html
Old May 7, 2003
Actually, BHP is the HP at the flywheel. It is also known as fan horse power, the fan, in this case, is the flywheel (spins just like a fan). The formula is easy:
HP = (Torque x RPM) / 5252
You can see that at 5252 RPM torque will always be equal to hp. When you look at a dyno, the lines should always cross at that point.
