Dyno results of supercharged hybrid K24A Accord engine from Hondata.
Old May 7, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
Thumbs up Dyno results of supercharged hybrid K24A Accord engine from Hondata.
You might want to think twice about getting a K20A/A2 swap.
This was not an exercise in power, but one to extract maximum torque.
Specifications:
Accord 2.4 bottom end (9.5:1 compression)
RSX-S head
Japanese Integra Type R camchafts
RC 550 saturated injectors
RSX-S six speed gearbox
Jackson Racing race headers and test pipe
Short ram intake
5 Zigen catback
Stock fuel pump and stock fuel pressure
Driving Impressions
This would have to be the most fun Honda I have driven. Flexing your right foot instantly delivers weapons grade torque and leaves you grabbing for the next gear. Most freeway onramps will have you well into three digits before you have to merge. This engine does not need to be redlined for a fast getaway though. Huge amounts of torque mean that corners normally negotiated in second gear can be taken in 4th or fifth. You can change from first gear to sixth with no hesitation. For long interstate trips sixth gear would be all you need for 80-120 mph cruising.
Thanks to Hasport for supplying the car and engine and to Jackson Racing for supplying and fitting the supercharger. Hasport sell a stiffer rear motor mount for this car which is needed to reduce engine movement under acceleration.
Check out http://www.hondata.com/dynok24rvsk24rsc.html
and http://www.hondata.com/dynok20rvsk24r.html
for more information.
Cliff notes:
This engine was embedded in an EP3.
Old May 7, 2003
cambo's Avatar
I wish I was asian
1. Jackson Racing Superchargers Blow more than Black99Vtec
2. The Dyno Runs were done on different days and times (1 morning, 1 at night)
3. Thats STILL an 80+ HP increase.
4. 57 ft/lbs. torque increase.
5. This says nothing about the HP potential of the k24 hybrid because this dyno was done in the interest for MAX TORQUE, not horsepower
Old May 7, 2003
guamcivic2k1's Avatar
YoUnG N SuXsExFul
so will this engine fit in our cars?
Old May 7, 2003
Giuseppe's Avatar
Giuseppe is an unknown quantity at this point
I'm impressed with the numbers. Yeah, Jaskson Racing isn't the best. However, those numbers seem very useful for everyday daily driving. I don't doubt that it'd be alot of fun to drive.
Old May 7, 2003
HomerSimpson's Avatar
Those numbers are great, but what are the chances of them coming out with a supercharger for the D-series?
Old May 7, 2003
GideoN's Avatar
GideoN is an unknown quantity at this point
Probably never. The only way to get that much output that fast would be swapping.
I would like to know also.
Old May 7, 2003
Slainte's Avatar
Slainte is an unknown quantity at this point
Re: Dyno results of supercharged hybrid K24A Accord engine from Hondata.
Cliff notes:
This engine was embedded in an EP3. [/B]
yay, it'll fit in my car!
Old May 7, 2003
bickford05's Avatar
bickford05 is an unknown quantity at this point
Thats sick, i just wish i had the money to do it
Old May 7, 2003
GideoN's Avatar
Ditto!
Old May 7, 2003
Rsxtc's Avatar
Rsxtc is an unknown quantity at this point
If i remember correctly, you'd have to have another 1-2 inches more clearance for the k24 block to fit into the EM2. The K20 was already a pretty tight fit.
Old May 7, 2003
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
nice...even better....hahaha
Old May 7, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
There is another thread, where HASPORT was claimed to be working on engine mounts for a K24 swap, if true, it will fit. The block is significantly taller than the K20, so there would be some issues to resolve (mainly having the engine sit lower in the chasis). Keep your fingers crossed, we may have a good frankenstien motor for bottom end.
For max power/ top end, i would still stick w/ a K20 swap (200HP stock)
Old May 7, 2003
papi2001civic's Avatar
papi2001civic is an unknown quantity at this point
if it fits sign me up
Old May 7, 2003
LJ's Avatar
LJ
Fernando The Donkey Lover
LJ is an unknown quantity at this point
wow, that is the best numbers in terms of gains i have ever seen come from a Jackson Racing product
Old May 7, 2003
Chrissy's Avatar
Chrissy is an unknown quantity at this point
good god, i wet myself, i need that for me!!
Old May 7, 2003
All Eyes On Z
Do I need to remind you the very reason why Honda's suck?
Does the title say "potential of K24 revealed"? No.
Do you see any other hybrid K-engines out there posting dyno results?
Still a significant gain over stock. It's not the best but only for a hybrid engine as of this point.
Old May 7, 2003
cambo's Avatar
I wish I was asian
correct the title does not say the potential of k24 hybrid revealed, but knowing some members on this board...they will think that dyno IS the max potential. Just making sure they dont think thats the max.
but i have seen other dyno results from other k20s and k24s.
Old May 8, 2003
prototype's Avatar
x-factor
HAHAHAHAHAHAHAHA THATS THE FUNNIST **** IVE EVER HEARD
CAMBO
Old May 8, 2003
SuperNegro's Avatar
SuperNegro is an unknown quantity at this point
not impressed by the numbers at all.
they should try it with a turbo and it might be intresting.
Old May 8, 2003
Got Boost???'s Avatar
Well if were talking about CFMs then i think black99vtec was it beat
Hes more on par with the blowing power of a T3 running 20 psi
Old May 8, 2003
Intermezzo's Avatar
Intermezzo is an unknown quantity at this point
Stop torturing us!!
Old May 8, 2003
Tiki's Avatar
Tiki is an unknown quantity at this point
Originally posted by Intermezzo
Stop torturing us!!
beat me to it
Old May 22, 2003
briang's Avatar
briang is an unknown quantity at this point
Here are some additional facts to this story.
The EP with the supercharged K24 belongs to Hasport. It is a stock K24 block mated to an RSX Type S head with Type R cams. We have revved it to over 8000 without problems yet.
Incidently, we are working on a K24 kit for the 01 and up Civics and should have it out in a couple of months. The clearance of the supercharger on the EM or ES Civics is almost identical to that of the EP.
To compare it to a trubo is an interesting idea. Since we also have a turbocharged K20 in our 01 Civic EX, let me share my thoughts.
If you are running the turbo and supercharged car at the same boost levels, the supercharger is more fun to drive and is faster too.
As for the K24 potential, the K24 block is stock at the moment. I am building an 11 to 1 compression ratio block for that car and will raise the boost on the supercharger a couple of pounds. I expect a significant increase in both torque and HP.
The car probably has some more potential even with the stock block. I believe the exhaust is a bit small for the HP and so is the throttlebody. I may have these fixed before the new block is ready.
brian g
Old May 23, 2003
GideoN's Avatar
Where do you work? You with Hasport?
Old May 23, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
Nice numbers. Keep us posted..
Old May 25, 2003
briang's Avatar
I work for Hasport
Old May 25, 2003
GideoN's Avatar
So you (Hasport) are making mounts for the K24A to be able to fit in a EM2 (7th gen) chassis?
Old May 26, 2003
cdmx's Avatar
^ phat phat phat!!!! love that siG!!!!
Old May 26, 2003
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
while we're asking about mounts. what happened to bseries mounts? you still working on those, or did that get put on the back burner?
Old May 26, 2003
briang's Avatar
I am buying a coupe to prototype the B-series mounts in. The delay is because it is one of 11 projects.
And yes we make the K24 bolt in kit for ES/M
brian g
