v8 vs w8?
Old May 5, 2003
  #31
cdmx's Avatar
ok, now compare it to a V8...how can you, the numbers would vary alot right?? different engines
Old May 5, 2003
  #32
speedracersong's Avatar
sibling rivilary.
fun stuff.
sorry just pwing.
Old May 5, 2003
  #33
Strebor's Avatar
Eee Tee Too (Ess DoubleU)
Strebor is an unknown quantity at this point
W8's don't sound as sexy as a v8.
Old May 5, 2003
  #34
RoadRunner's Avatar
geez, why dont other companies do the same thing and put like those in acura's and our civics ?????
Old May 5, 2003
  #35
Boilermaker1's Avatar
Jap-Euro Fusion
The W8 is 2 VR4s put together. It's a space saving design.
a normal V8 looks like this
|O| |O|
|O| |O|
|O| |O|
|O| |O|
The W8 Looks like
|O | | O|
| O| |O |
|O | | O|
| O| |O |
But the cylinder bores would be closer to each other (I can't draw in between the text lines)....
The engine joins 2 15 degree banks of 4 cylinders at 60 degrees to each other. Each head has 2 cams (although VW calls it SOHC because each bank is technically a V engine), one for intake one for exhaust.
It doesn't really look like a W.... it looks like this.... \\ // But because the cylinders are offset, it isn't truly a V, but I don't know that you can really call it a W.... it just sounds cool.
Old May 5, 2003
  #36
DRJ's Avatar
DRJ
DRJ is an unknown quantity at this point
Everything you could want to know about the VR and W engines:
http://autozine.kyul.net/technical_s..._packaging.htm
Old May 5, 2003
  #37
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
*Grab bag of popcorn*
I agree with Boilermaker1, its a space saving design.
