Need Help wth a coilover question
Old Dec 10, 2002
Rollin0n18s
Guest
Posts: n/a
At the moment I have Eibach sportlines lowering springs, with factory struts and I have about a half inch of play from my tire to my fender. So I need to get coilovers, My plan is to get coilovers and koni's all around. Does it really matter what kind of coilovers(Cheap vs. Expensive) I get as long as I get the Koni's or should I get an expensive set of coilovers also.
Do you really feel the difference between the koni's and the Factory struts?
Can you guys recomend some coilovers that aren't to expensive?
Also is the ride quality worse with coilovers than lowering springs?
Old Dec 10, 2002
CarbonFly's Avatar
Ground Control's are the only sleeved(cheap in other words because they aren't TRUE coils) that I would ever recommend getting. They use Eibach springs.
Old Dec 10, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Or Skunk2s which are just Ground Controls with a different name (and cheaper)... don't forget... there is a suspension section in the forum. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Dec 10, 2002
JRS1's Avatar
JRS1 is an unknown quantity at this point
I have Skunk2 coilovers and they are great. They are very cheap and will work well with after market shocks.
Old Dec 10, 2002
CarbonFly's Avatar
I've heard the Skunk 2's have a tendency to break........anyone have problems like that? I just want you all to remember the you stated that they were cheap.
GolNat
Jan 12, 2021 09:06 PM
SoslowEj666
Mar 8, 2016 01:10 AM
JKWood
Jul 28, 2015 03:45 PM
mHo2
Jul 27, 2015 12:57 PM
EM_WON
Jul 22, 2015 06:49 PM
