do you like?
Old Dec 8, 2002
neeedforspeeeeed's Avatar
neeedforspeeeeed is an unknown quantity at this point
do you like?
K1 Attack if its a repost, im sorry, but i searched and found nothing on it so i figured id post it. Personally, i like it, and wanted the opinion of some of the people on the site.
Old Dec 8, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Kewl!
Old Dec 8, 2002
cambo's Avatar
I wish I was asian
i like!
only wish i had an accord and 16gs
Old Dec 8, 2002
player's Avatar
Is that an accord which is modded to become that???
that thing is beautifull,
Old Dec 8, 2002
Quote
[hr]Originally posted by: player
that thing is beautifull, [hr]
nope...the accord is a donor car for (sorry for the long post):
Running powertrain
(engine + transmission assembly)
Engine mount rubber bushings
Alternator
Starter
Battery
Exhaust collector
+ lambda sensor
+ catalyst converter
Water radiator with electric fan
Water pump
ECM
(electronic control module)
Complete wiring
+ all sensors
+ fuse box
Ignition cylinder
+ key
Fuel pump with fuel level sender
Drives shafts L&R
Powertrain subframe
(front & rear crossbar) Front spindles with bearings L&R
Front axle Upper control arm L&R
Front axle Lower control arm L&R
Front axle torsion bar
Front brake assembly
(L&R brake rotor+calyper)
Steering joints L&R
Shifting lever assembly with linkage
Instrument panel with gauges
Pedal assembly
(brake, clutch, gas throttle)
Clutch cylinder with vessel
Brake cylinder with power booster and vessel
Parking brake lever
Heater & defroster assembly
Steering column with blinker/wiper levers
Rack & Pinion steering housing
Windshield wiper motor with console
Windshield washer assembly
Windshield glass
Miscellaneous nuts, screws, washers,
fasteners, clips and etc.
its transplanted into a tubular chasis that they make
Old Dec 8, 2002
Engineman's Avatar
T.V. is bad for you. Go outside.
Engineman is an unknown quantity at this point
That is sweet.
Old Dec 8, 2002
notsodiseased's Avatar
notsodiseased is an unknown quantity at this point
yea thats a repost but its a damn good one that i have been wondering about for quite some time. good job
Old Dec 8, 2002
BlueRevs's Avatar
BlueRevs is an unknown quantity at this point
that car looks hella tight
Old Dec 8, 2002
XxJDMCivicxX's Avatar
That thing is sweet too bad I don't got the $$$ for it.
Old Dec 8, 2002
RedDragon333's Avatar
Yea a repost but it was a long time ago, its cool tho
Old Dec 9, 2002
CivicRyder's Avatar
CivicRyder is an unknown quantity at this point
Quote
[hr]Originally posted by: neeedforspeeeeed
K1 Attack if its a repost, im sorry, but i searched and found nothing on it so i figured id post it. Personally, i like it, and wanted the opinion of some of the people on the site.[hr]
Is this the 8th generation Civic protype??? ... lol [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
