Honda makes forged 12.5:1 Compression pistons for our cars!!!
Old Nov 19, 2002
mohawkboom's Avatar
Civic GX Specs
Yup..on their natural gas model.... same bore..same stroke..12.5:1 compression!!!
Old Nov 19, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
you're gonna have to do more to that engine than just puttin those pistons on...
Old Nov 19, 2002
mohawkboom's Avatar
I doubt it..we have domed heads..the pistons are the same..just domed..they should fit no problem..but they may not leave enoughclwarance for an aftermarket cam..
Old Nov 19, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
He was referring to building up our bottom end, which I agree on, you'd prolly need a new crank and rods at the very least. Can't just up compression that much without building up the rest of the motor.
Old Nov 19, 2002
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
will someone please figure this out
Old Nov 19, 2002
mohawkboom's Avatar
sure you can..the OEM rods aren't that weak.. it's not under any boost so it's not a problem...the GX uses the same rods and crank as we do. heads a re a little different ..but cumbustion chambers are the same
Old Nov 19, 2002
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
Ok, so say we put these in our cars, what kind of gains are we talking about here?? I have a LX so my compression is pretty low, so what would the gains be?? and would they be worth it??
~nick~
Old Nov 19, 2002
mohawkboom's Avatar
well... rough estimate..about 11-13 HP and about 10 ft.lbs of torque right through the power band
Old Nov 19, 2002
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
stupid question, is high or low compression better for turbo/n20[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Nov 19, 2002
SleeperCivic's Avatar
SleeperCivic is an unknown quantity at this point
Hmmm, interesting... I'm thinkin that you'll need some high octane to run that compression. What octane do ya think would work? 92-93??
Old Nov 19, 2002
jwcardy's Avatar
yeah, i have that same guestion too, cause i am almost finished with my turbo kit and want to know if this would be beneficial to me
Old Nov 19, 2002
aznsmtboy's Avatar
aznsmtboy is on a distinguished road
in a perfect world, high compression and boost is most optimal but, since we have to deal with alot of variables, low compression and boost is most reliable and practical.
Old Nov 19, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Quote
[hr]Originally posted by: CrazyCakes
stupid question, is high or low compression better for turbo/n20[IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
I believe low compression is better for forced induction. somewhere in the 8-9:1 range is good. 12.5:1 is for going N/A.
Old Nov 19, 2002
mohawkboom's Avatar
if you're going to boost your car or run N2O lower compression is better.or keep the stock compression but get forged pistons for proper heat dissipation..
the 12.5:1 pistons might not be too beneficial, Ignition may have to be retarded to run them properly in which case gains may not be beneficial...11.5:1 is about the highest one can go without some serious ECU programming...
I can get 4 pistons made for $1400CAD at 11:5:1 compression... $800 fr the pistons $600 for the CNC program to make them. After their made it's only $800CAD ($500us) for the pistons as long as you have the job number (CNC program)
Old Nov 19, 2002
C2i0v0i1C's Avatar
SuperMODrizd
FI=lower compression NA=higher compression
Old Nov 19, 2002
C2i0v0i1C's Avatar
SuperMODrizd
also what the hizell is honda thinkin these days, that 2003 gx is not only natural gas powered but it has SULEV....next thing you know there wont be any emmsions at all.
Old Nov 19, 2002
TwilightX's Avatar
TwilightX is an unknown quantity at this point
Quote
[hr]Originally posted by: C2i0v0i1c
also what the hizell is honda thinkin these days, that 2003 gx is not only natural gas powered but it has SULEV....next thing you know there wont be any emmsions at all.[hr]
lol - far be it from a company being environmentally smart about their engineering
Wish there was some balance between the two - high performance, and low emissions - and I mean like ***** out 400 monster block power, but still won't create smog...oh well...gotta tip the scales to some degree right?
Old Nov 19, 2002
mohawkboom's Avatar
well honda makes a 240 HP 2.0L ULEV [IMG]i/expressions/face-icon-small-smile.gif[/IMG].. imagine if they used that technology to make a 3.0L V6
Old Nov 19, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
the s2k is ulev? really?
Old Nov 19, 2002
S2000man01's Avatar
O RLY
Yup S2k is ULEV. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Changing the pistons works IF the head/block on the GX car is the exact same as the head/block on the 7th gen civic.
No, you don't need new rods or crank, as the rods and crank on your cars are forged and can probably take quite a bit of HP before ever having to change them. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
But there are many more clearances to measure, like piston to wall, piston to valve, etc, etc. So it may be more than just changing the pistons.
Old Nov 19, 2002
mohawkboom's Avatar
I called Honda in NY for this..the Blocks, Rods, cranks, combustion chambers and valves are all the same...the GX's have different cams and completely different injectors..the Pistons would fit no problem..but the compression is too high to be streetable..and without new cams, fuel map, Ignition system..it would probbaly hinder power...if their swapped in while retaining the stock ECU..Ignition will be retarded and power will be lost..
Old Nov 19, 2002
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
Quote
[hr]Originally posted by: TwilightX
Quote
Wish there was some balance between the two - high performance, and low emissions - and I mean like ***** out 400 monster block power, but still won't create smog...oh well...gotta tip the scales to some degree right? [hr]
how about the next NSX? it's supposed to be a hybrid. with the electric boost for added performance. and get 50% better fuel economy than all of its' competitors. about 400hp with the electric motor if i remember correctly.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
jessicakaybby
Apr 20, 2015 12:11 PM
BREADFAN
Apr 15, 2015 08:58 AM
ImmortalEX
Oct 31, 2001 10:00 PM
