is it normal for idle to go up a little when.....
Old Nov 16, 2002
xe2k2's Avatar
xe2k2 is an unknown quantity at this point
you turn on the headlight?...I noticed that during night driving my idling rpm is about 800-850 supposed to 750 during day driving. What controls idle? and can i adjust it if i want to?
Old Nov 16, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Mine does the same....it just jumps up a little bit and goes back to normal.
same thing with A/C...but it makes sense why.
Old Nov 16, 2002
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
i think that the more electricity you use... the more the engine will work to turn the alternater to recharge the battery and with the A/C it does the same to turn the compressor pulley
Old Nov 16, 2002
MadWheel's Avatar
Premium Boosted Member
correct
Old Nov 16, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Odd but normal. Hell, the headlights dim when the car is about to stall. Everything in your car just about depends on electricity.
Old Nov 16, 2002
WannaBFast's Avatar
Prowlin' with a Purpose
heres a solution... get a power pulley..... that will fix it... i think...
Old Nov 17, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
Quote
[hr]Originally posted by: WannaBFast
heres a solution... get a power pulley..... that will fix it... i think...[hr]
lol u thinking of the aem ones? those underdrive the alternator and powersteering..
Old Nov 17, 2002
LudlamTheory's Avatar
i boogie for the raindrops
AEM pullies are bigger than the oem so that the alternator spins less, and the engine can keep more of the HP for itself...i've been trying to find an alternator shop that will make me a pulley that is smaller than the OEM so that my alternator can charge more at idle....you know youre a true stereo junkie if you dont mind giving up engine power to get louder
Old Nov 17, 2002
IllusiveImports's Avatar
IllusiveImports is an unknown quantity at this point
also your engine is programed to idle higher when its cold since there is a greater risk of stalling your engine but its ok thats what sposed to happen
alxz310
Jul 30, 2015 12:18 PM
mistermenphis22
Jul 13, 2015 04:43 PM
671civicLX
Jul 4, 2015 04:02 PM
Kaelin
Jun 19, 2015 04:19 PM
thana
Jun 15, 2015 11:58 PM
