Try freezing your intake air -> more power? hmm
Old Nov 7, 2002
SleeperCivic's Avatar
SleeperCivic is an unknown quantity at this point
Check this out - found it on the SEMA website - pretty radical. I wonder if it works?
Design Engineering Inc. CRYO2-Air Charge Freezer
Old Nov 7, 2002
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
why not just jet nitrous? it does the same thing + adds power through enriching the 02 mixture.
Old Nov 7, 2002
Gryphin's Avatar
00 Hatchback Owner
makes the air 35% colder but for how long? once your engine starts going i would want that 35% to stay cold and keep my engine cold
Old Nov 7, 2002
HondaGuru's Avatar
its good for a run down the 1/4 mile. you would undoubtedly have to spray for each run though.
Old Nov 7, 2002
Ya, I'd wonder how long it would last and what they say the advantages are to nitrous... I can't imagine there is much power to be had there compared to a basic 50 shot of nitrous. 35% cooler air, hmm 100 degrees minus 35 degrees = 65 degree air coming into the engine. What would that be, maybe 5 hp ?? Now, where is that ratio of air temp to hp gained...
I checked the website but they don't have it on yet Design Engineering
Old Nov 7, 2002
torqen2k1's Avatar
torqen2k1 is an unknown quantity at this point
Try to stick your air filter in your freezer for a little while and then put it on! I tried it [IMG]i/expressions/laugh2.gif[/IMG]and it worked for like a couple of seconds.
Old Nov 7, 2002
HondaGuru's Avatar
hell, you can get the same cooling factor, plus a slight bump in power even with a 25 or 30 shot.
Old Nov 7, 2002
civichx81's Avatar
civichx81 is an unknown quantity at this point
haha i tried using just nitrous in the intake and it cooled it.its just a small jump. it feels like i have a prelude and vtec kicked in.
Old Nov 8, 2002
OyD's Avatar
OyD
OyD is an unknown quantity at this point
i'm not going to attempt the math, but i've been told that you gain only 1 hp for every 10-11 degree drop in temp.
Old Nov 8, 2002
IronFist's Avatar
I'm suprised no one has said "what if you reroute the A/C into the intake?" yet. [IMG]i/expressions/laugh2.gif[/IMG]
IronFist
Old Nov 8, 2002
jps's Avatar
jps
jps is an unknown quantity at this point
I would say that it would geatly increase your chance of hydrolocking your motor! The metals temp would be below the dew point so condensation would form and then be sucked right into your engine hydrolocking it.
Old Nov 8, 2002
Niter1dah's Avatar
Niter1dah is an unknown quantity at this point
Quote
[hr]Originally posted by: IronFist
IronFist[hr]
Bwahahaha thats hella funny [IMG]i/expressions/laugh2.gif[/IMG] Someones gonna make a kit for it. Probably by the makers of the Electric turbo supercharger
Old Nov 8, 2002
WD40's Avatar
WD40 is an unknown quantity at this point
"Dyno testing has shown up to a 35% drop in air charge temperature."
Since when has a dyno measured air temperature?
Old Nov 10, 2002
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
Not a bad idea, but not worth the money...if you want to do something like that, redirect your AC vents somehow to your intake and ur done ;]
Nah but freal tho...if you really wanna do something like that just shoot some nitrous....
Old Nov 10, 2002
JohnnyLee's Avatar
7thgen guh chee
I didn't see a price?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Nov 10, 2002
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
Quote
[hr]Originally posted by: WD40
Since when has a dyno measured air temperature?[hr]
Dyno's test alot more than just horsepower and torque, think about it, how are you going to test the temp if you are driving the car on the street....with a dyno your going 100 but not moving...easier to take measurements. They also test a/f ratio's egt's etc, etc...
lienhart88
May 19, 2015 08:48 PM
ORskier
May 7, 2015 04:54 PM
carid
Apr 30, 2015 07:00 AM
cloudguy
Apr 28, 2015 05:02 AM
plastikman
Bolt-on Engine Performance
Dec 13, 2001 03:18 PM
