To downshift or Not to downshift
Old Nov 5, 2002
sumama's Avatar
sumama is an unknown quantity at this point
When you're driving at about 50 mph and need to brake, do you guys downshift or just brake on neutral? Some people say it's better to downshift because you're putting less pressure on your brakes. Other people say it's better to brake on neutral because by downshifting, you're wearing out your clutch and wasting a little gas, and new brakes cost less than a new clutch. So does everyone downshift or not?
Old Nov 5, 2002
BumpinCivic2k1's Avatar
BumpinCivic2k1 is an unknown quantity at this point
i have been wondering the same thing...does anyone know?
Old Nov 5, 2002
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
Think about it. Whats costs more, brake pads or a new clutch and or transmission?
Engine braking is good for steep downgrades, over long distances because brakes tend to build up heat and boil its fluid after long periods of constant use. This is why you SHOULD downshift to slow in these cases. Its also a good technique when racong. As for everyday driving around town, no. Just put it in neutral and brake to a stop.
Old Nov 5, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
unless you need to brake hard, and the engine breaking can help, i like to just leave it in gear and brake, no need to downshift, no need to put it into neutral..
Old Nov 5, 2002
HondaGuru's Avatar
... umm except if you are going to come to a complete stop you need to have in it neutral unless you intend to ride and wear out the clutch or stall the car.
Old Nov 5, 2002
mwwhonda's Avatar
well yes.....depending upon what gear i am in determines how long i brake before i depress the clutch pedal....obviously
Old Nov 5, 2002
noypirider's Avatar
noypirider is an unknown quantity at this point
i suggest don't put the gear in neutral when stopping. it's a no no. you can feel that you lose some gear advantage in controlling your car. with regards to break or downshift, you can always do either. depends on the situation. if you have enough space to stop, you can use your breaks. but if you don't have enough time to stop in an instant, downshiftimng with the use of your breaks is the solution.
if you are not racing, i suggest you use your breaks so that you will not rapidly wear your engine, transmission, and clutch. these are more expensive than break pads.
Old Nov 5, 2002
BlueRevs's Avatar
BlueRevs is an unknown quantity at this point
Its become a habbit for me to slow down put it in nuetral and when i get to 25-30 mph start to downshift into second. then i brake at about 15mph in neutral, and then of course stop. So basically i just mix it up.
Old Nov 5, 2002
ALLcustom2k1's Avatar
ALLcustom2k1 is an unknown quantity at this point
raise your hand if you know the difference between the words "break" and "brake"
just kidding... man, i wish i had a 5-speed... [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Nov 5, 2002
Blown's Avatar
Blown is an unknown quantity at this point
I downshift. I've had this discussion with numerous people(and driving instructors) and I still believe downshifting is better. The driving schools here teach you to put in neutral and brake. I disagree with this! First off, when slowing down, what would happen if someone was about to rear-end you? If you had it in neutral, it would take you longer to get it back into gear and get out of the way and chances are you'll be rear-ended. Another benefit of downshifting is when you're slowing down on icey roads. I prefer to let the engine slow me down just in case the intersections are iced up. Our cars are tail-happy on icey roads and all it takes is to lock the rear tires for a second and you'll lose it! Now, how about bumper-bumper rush hour traffic? Would it be wise to keep on putting it in neutral to stop everytime traffic stops? Now, what about speed-sensative steering that adjust the steering according to what gear you're in?
Old Nov 5, 2002
01civic911's Avatar
01civic911 is an unknown quantity at this point
i always downshift, if you do it right, its not stressing anything or burning the clutch. i would just much rather have my car in a gear at all times for the reasons of just having the ability to accelerate without slipping into a gear again. takes just as much work to go into neutral as it does another gear, so why not have control?
Old Nov 5, 2002
n00dleboy's Avatar
n00dleboy is an unknown quantity at this point
Downshift. Putting it to neutral and braking is for newbies. When properly downshifting (rev-matching) , it is virtually the same as upshifting when accelerating. What if a deer ran across the road and you needed to accelerate out of the way? The time for you to determine the appropriate gear and then depress the clutch then shift into gear, release the clutch, is WAY slower than if you already had the car in gear.
Old Nov 5, 2002
Blown's Avatar
Noodleboy - Can you believe the AMA(Alberta Motor Association) driver instructions teach students to put it in neutral and brake to slow down? At least you see it the way I do as well. Leaving it in neutral leaves you more open for problems!
Old Nov 5, 2002
n00dleboy's Avatar
Yup i attended a racing school for 3 weeks over in Ontario (Jim Russel Racing school ) - they say always always leave the car in gear. Can't believe driving schools tell you to put it in neutral.
Old Nov 5, 2002
HondaGuru's Avatar
Like i said, its just added stress on the tranny. no matter how minimal, why whould i want to put undue stress on my drivetrain? For "control" purposes? Im talking about bringing the car to a complete hault from gear (say ~20 or lower). UNless im on a steep downgrade or on black ice, there is NO need to for to keep it in gear.
You are confusing slowing the car down, and stoping the car. I am and always have been refering to the latter.
Old Nov 5, 2002
icey's Avatar
icey is an unknown quantity at this point
it all depends how much gas is in the tank......makes me feel like i'm saving gas when the needle is to the right of E[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Nov 5, 2002
Bellz's Avatar
To me, it depends on the situation. If it's raining or the roads are slick, you should let the engine help with braking. This is especially important if you're not driving an ABS equipped car, like my DX. In normal driving, on dry roads, it's not necessary if you're only slowing down for a red light. If you were driving like an idiot, engine braking might help you slow down faster. I believe it does put stress on the clutch, but you're putting stress on the clutch when you accelerate hard too. In snowy/icey conditions, you'd better know how to slow the car down with the clutch, or you may end up in a ditch or someone's front yard.
I see soo many idiots around here driving camaros and mustangs with snow all over the road. This might not be too bad up north, where people are used to it, but down here in the south, most people don't have the experience to drive in snowy weather.
Another amazing fact is that a lot of people don't know the proper technique for using ABS brakes. Many think that they should still pump the pedal to stop, when just the opposite is true with ABS. You have to keep pressure on the brake for the ABS to do it's job. Non-ABS cars (like the DX again) should know the pedal pumping method to avoid sliding in rain/snow. Combine this with downshifting, and you can keep from becoming an insurance statistic.
Old Nov 5, 2002
Mbow's Avatar
I leave the car in gear while pressing the brake. I don't go to neutral until just before the car starts to shake a little as I approach a complete stop.
I never downshift to slow down or stop the car unless I am flying and don't want to cook the brakes.
If I am getting ready to turn, I often apply light pressure on the brakes and downshift to the lower gear getting a little more braking so I can immediately accelerate out of the turn.
Everytime you shift, a little wear is going on the clutch. I plan to keep my car for a very long time. That minimal wear on the clutch will add up.
BTW, I drove an accord to 150k on the oe clutch and it was still going strong.
Old Nov 5, 2002
HondaGuru's Avatar
making the engine stumble like that sint good for it. id suggestyou do that BEFORE it "shakes a little". hence my previous post.
Old Nov 5, 2002
Mbow's Avatar
Quote
[hr]Originally posted by: HondaGuru
making the engine stumble like that sint good for it. id suggestyou do that BEFORE it "shakes a little". hence my previous post.[hr]
Which part of "...just before the car starts to shake a little..." did you miss? [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Nov 5, 2002
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
I don't know whats good or bad for the car, but I always downshift. Like someone up there said, if you match the rpms right it'll be fine for your engine, which is what I think too. Each gear I downshift into and let off the clutch, my rpm is always below 3K so its not stressing the engine at all. Its as if you were in that gear accellerating and then let go of the gas and your car starts to slow down, same thing.... Downshift in my book....
Old Nov 5, 2002
Bluelle's Avatar
Bluelle is an unknown quantity at this point
downshift
Old Nov 6, 2002
sumama's Avatar
I guess the answer is to DOWNSHIFT
Old Nov 6, 2002
sumama's Avatar
Actually I still don't know the answer. There are pros and cons for each.
Old Nov 6, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
I know it's bad for my clutch (I hope it dies b4 warranty ends)...but I downshift as far as 2nd while decelerating. The brakes on our cars are just so puny...I don't feel safe unless there is some engine braking helping me slow down.
Old Nov 6, 2002
DIMO's Avatar
DIMO is an unknown quantity at this point
When I slow down I just rev-match to the lower gear. This is the proper way to slow down if your going to engine break. Also good practice for auto-crossing[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Nov 6, 2002
n00dleboy's Avatar
Quote
[hr]Originally posted by: PESTLNC
I know it's bad for my clutch (I hope it dies b4 warranty ends)...but I downshift as far as 2nd while decelerating. The brakes on our cars are just so puny...I don't feel safe unless there is some engine braking helping me slow down.[hr]
If warranty covers your clutch then u're lucky. Warranty NORMALLY doesn't cover parts that break down due to normal wear and tear ie: clutch, brake pads...etcetc..
Old Nov 6, 2002
DC5@EM2's Avatar
DC5@EM2 is an unknown quantity at this point
I downshift and will always downshift. I feel its an overall better situation to be in if anything happens, yeah it may cause a little more wear and tear, but I feel its worth it in the long run.
Old Nov 6, 2002
Blown's Avatar
Quote
[hr]Originally posted by: n00dleboy
Quote
If warranty covers your clutch then u're lucky. Warranty NORMALLY doesn't cover parts that break down due to normal wear and tear ie: clutch, brake pads...etcetc..[hr]
I thought there was like a 5000km warranty on the clutch. I know on the jeep I owned had a 10K KM warranty on the clutch.
Old Nov 6, 2002
PESTLNC's Avatar
Dammit...guess I didn't read the fine print. Well, hopefully I'll be driving something else before it goes.
