Possible reason the new Si isn't so good?
Old Oct 25, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
I'm not sure how much to trust SCC's numbers or analysis, I haven't been getting it long enough. But they say, at low RPMs one intake valve follows the primary lobe, and the other follows a secondary smaller lobe, and the i-VTEC in the K20A3 activates at 2300 where only the intake valves change to the high cam profile. The exhaust valves never change over, thus the reason for the whimpy performance, lack of 8000+ RPM redline and no scream. Basically, the 11:1 compression and the 2.0L Displacement account for the 33 HP over the EX. Essentially, they have the same VTEC system as we do, just with an extra camshaft that has fixed timing. It's no faster than the EX (they clocked a 1/4 in 16.2/85.1).
Does anyone know if this is true?
Meanwhile the K20A2 has all the goodies.
Old Oct 25, 2002
CarbonFly's Avatar
Now that's interesting.......makes me glad i stayed with the EX and not go with the egg shaped Si.
Old Oct 25, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
yup..they dont have "performance" VTEC as its called...on both the intake and exhaust cams.
Old Oct 25, 2002
macrossranma's Avatar
macrossranma is an unknown quantity at this point
the new Si is definitely faster than ex, but slower than old Si
Old Oct 25, 2002
mikalem's Avatar
mikalem is on a distinguished road
I get that mag too, actually just read the article about the homebuilt CTR, I believe they mentioned that the day they did the tests it was hot out, like REALLY hot out. So those numbers listed are a tad lower than they should be.
Old Oct 25, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
umm.....well, im confused
i thought that the b series engines w/ DOHC VTEC only acuated one cam as well, the exhaust cam......the first "VTEC" noise that you hear is not the intake camshaft changing, but instead the secondary intake manifold opening or changing.....then when the car goes nuts in the higher rpms ( i think around 6k rpm) that is in fact vtec engaging and switching the exhaust camshaft lobes over....
Old Oct 25, 2002
sevenincubus's Avatar
sevenincubus is an unknown quantity at this point
Ok the K20A3 doesnt have all the goodies the K20A2 does. I wondering about the K20A2 type s and K20A2 type r. I heard the only difference is the exhaust and something with the ecu? So what is the difference?
Old Oct 25, 2002
NeoMagus's Avatar
There is no K20A2 Type R. It is K20A. Higher compression, higher redline, more aggressive camshafts, factory port and polish to say the least.
Old Oct 25, 2002
WeakVTEC's Avatar
WeakVTEC is an unknown quantity at this point
I haven't driven, sat in, or seen a new Si that ran a quicker time than me with proof, or at the track.
Old Oct 25, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Quote
[hr]Originally posted by: NeoMagus
There is no K20A2 Type R. It is K20A. Higher compression, higher redline, more aggressive camshafts, factory port and polish to say the least.[hr]
The new K20A engine in the Type R is NOT ported and polished. Honda used a method on the engine heads that resulted in further porting and polishing the engine wasn't necessary.
As per HT:
The differences between the Type R and the American Type-S are subtle, but noteworthy. The engine is designated as a "K20A," but there's no numerical distinction. In Japan, the engine is rated at 220 hp and 152 lb-ft of torque. This difference is achieved through a few tricks, however, these engines do not undergo the meticulous hand porting of the B18C5. Instead, the differences are due to better breathing, compression and computer tuning.
The head on the Type R is cast using a special process with finer grains of sand. The result is smoother intake and exhaust ports, sufficiently smooth that they don't require additional hand porting. The exhaust system is quite different though. In the U.S., the exhaust is immediately collected through a short header into the catalytic converter. Basically, the converter itself is the downpipe for the exhaust system. The Japanese Type R, however, uses a much freer flowing system that is essentially a classic "tri-Y" header. The catalyst is much further down the exhaust stream, allowing for the freer flowing system. These changes certainly account for a good chunk of the Type R's increased power.
Another important factor is the increased compression ratio. The American Type-S has a good 11.0:1 ratio, but the Type R uses different pistons with a chromoly skirt. The compression rate is even higher, at 11.5:1. It also means that the Type R really wants to drink high-octane Japanese gasoline. 100-octane gas is sold at the pump in Japan, cushioning the system against detonation much better than the 91-octane swill we have in California.
More about the K20A and Ziel/JIC-Magic's RSX Type "R".
Old Oct 25, 2002
SoNiCcIvIc's Avatar
Makes the Si sound deprived.
And for the lazy, here is the Type R's "tri-Y header" and cat-converter. Looks pretty sick.
Can I put that on my car? On top of that the exhaust note sounds shaweeeeeeeet.
Old Oct 25, 2002
Neonmike's Avatar
Neonmike is an unknown quantity at this point
It's pretty simple. The new Si is damn heavy. If it was under 2400lbs like all of the older hatchbacks, they'd have a winner. But they're going the way VW went. Look at the old late 80s early 90s GTis and then compare them to new ones. They've gained almost 1000lbs! Pity honda is going that way, but i guess that's what happens when a car is designed in europe.
Old Oct 25, 2002
JohnnyLee's Avatar
7thgen guh chee
Quote
[hr]Originally posted by: SoNiCcIvIc
Can I put that on my car? On top of that the exhaust note sounds shaweeeeeeeet.[hr]
That looks bad
Old Oct 26, 2002
SoNiCcIvIc's Avatar
Quote
[hr]Originally posted by: Neonmike
It's pretty simple. The new Si is damn heavy. If it was under 2400lbs like all of the older hatchbacks, they'd have a winner. But they're going the way VW went. Look at the old late 80s early 90s GTis and then compare them to new ones. They've gained almost 1000lbs! Pity honda is going that way, but i guess that's what happens when a car is designed in europe.[hr]
I think most recent cars are natually heavier than their previous generations. Car makers sacrificing performance for the convenience of luxory or in other words that sense of "refinement." Because of the new Si, the new 200HP Civic Type R might make you wonder about it's performance. I don't have any #s but I do have my friend who's overseas with the experience. He told me the new Civic Type R is not as good as the previous 160HP one and though Type Rs are lighter, the CTR from what it seems doesn't seem light enough. The engine is the same as the Type S as we all know but the previous CTR hatch actually felt like more on terms with being a performance car and ends up being the preferable one of the two CTRs.
Old Oct 26, 2002
Neonmike's Avatar
Yet honda america somehow managed to make the civic coupes lighter than the previous ones (yaay struts!).
Old Oct 26, 2002
mwwhonda's Avatar
Quote
[hr]Yet honda america somehow managed to make the civic coupes lighter than the previous ones (yaay struts!). [hr]
yeah, umm, id rather the car be the same weight as the 6th gen, and still have double wishbones
Old Oct 27, 2002
SoNiCcIvIc's Avatar
Quote
[hr]Originally posted by: mwwhonda
Quote
yeah, umm, id rather the car be the same weight as the 6th gen, and still have double wishbones [hr]
I don't see why people look down on the MacPherson suspension. The 98 Spec Integra Type R is double-wishbone right? The new 2k1 Integra (RSX) Type R has the MacPherson as well in the front and will run circles around the DC2R.
Old Oct 28, 2002
mwwhonda's Avatar
Quote
[hr]Quote
Quote
I don't see why people look down on the MacPherson suspension. The 98 Spec Integra Type R is double-wishbone right? The new 2k1 Integra (RSX) Type R has the MacPherson as well in the front and will run circles around the DC2R. [hr]
handling and ride quality are two completly different issues, espcially when it comes to aftermarket parts...
a stock 01 type r may not handel as well as a 02 rsx-r...BUT the 01 will most definetly ride smoother, more comfortably, and have NO bumpsteer!
in addition, if aftermarket parts are implicated, the 01 will not only handle better, but will still retain acceptable ride quality, where the 02 rsx will have almost no suspension travel, and an extreme amount of bumpsteer.
face if guys, honda made a mistake.......bring the double wishbones back
Old Oct 29, 2002
SoNiCcIvIc's Avatar
Quote
face if guys, honda made a mistake.......bring the double wishbones back [hr]
Wrong.
First of all, the JDM "RSX-R" was born as a 2k1. A year later Acura gets the 4th generation Integra for 02 but I'm sure you know that.
Second. Ride comfort in the DC2R was horrible for people who don't live on smooth roads. It was not the best compromise to increase the handling. In fact, people complained about it so much, with the new "RSX-R" Honda raised the ride height for a more comfortable ride... AND it handles better than the older Integra Type R.
Do you need proof?
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
