b20 with type r head
Old Oct 20, 2002
sauado's Avatar
sauado is an unknown quantity at this point
is this cr vtec better than a b18c5 type r coz it has a better torque
and how much is it gonna be?
Old Oct 20, 2002
JoeB16's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
JoeB16 is an unknown quantity at this point
yea a B20B/B18C5 hybrid is possable, but its much less expensive for a B16A head swap. Take that, then turbo it, it can handle MAD boost.
Old Oct 21, 2002
Black99Vtec's Avatar
first member with a d16 swap
Black99Vtec should not be trustedBlack99Vtec should not be trustedBlack99Vtec should not be trusted
the ultimet hybrid is a b20 bottom end with the type r head or a h23 bottom end with a h22 head
Old Oct 21, 2002
JoeB16's Avatar
and why is a B20/itr the "ultimate" hybrid liar boy?
Old Jun 19, 2003
Chrissy's Avatar
Chrissy is an unknown quantity at this point
wouldnt the b20 type r head with ls gears give good top end, they mentioned it in the short movie "the last race"
Old Jun 19, 2003
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
With large displacement engines that deliver most of their torque in the low RPM range, you typically want longer gears. With the opposite (small displacement, low torque), shorter gears are preferable.
I know a lot of people with CRVTEC engines choose to swap in the Type R transmission because of the shorter, more aggressive gearing. I don't know of many people who choose to stay with the long LS gears if they have better options.
Old Jun 19, 2003
SuperNegro's Avatar
SuperNegro is an unknown quantity at this point
B20 Block with B18C1 head and B16/ITR style intake manifold is a better option.
As for gearing LS trannys are OK for turbo but would rather go with B18C1 or B16A/ITR with a LS 5th gear and probably the 4.7 FD over the 4.4.
Long gears will give you a higher top speed but that means jack **** if you dont have the HP to get you there.
B18C with a LS crank and resleeved is something i would take over a LS VTEC or B20 VTEC conversion just for the fact you dont have to screw around with the head and run an external oil line.
As for the H23 Block and H22A head, just keep the H22A and swap in the 95mm H23/F22 crankshaft & Rods for the stroker effect.
Old Jun 19, 2003
Chrissy's Avatar
yeah, i plan on getting a b20 block with the type r head on my crx with i guess type r tranny, since you say the gearing is more aggressive. i hope the whole thing will fit on this tiny body of the crx. would the type r ecu work with that setup?
Old Jun 19, 2003
SuperNegro's Avatar
wiring up an OBD2 engine into a non OBD crx should be fun but the ITR ecu will work on that engine.
Old Jun 19, 2003
The CRX is OBDI, but yeah the Type R ECU should work fine. I would check with a shop with a lot of experience in CRVTEC just to be sure, though. You may also think about using an EMS like Hondata to make sure everything is tuned correctly. Hondata actually works really well with OBDI setups.
Some CRVTEC setups can rev up to 10k RPM if tuned properly. The key is in the last two words, though.
If you're in the Southern California area, ImportBuilders (http://www.importbuilders.com) has a ton of experience building CRVTEC engines. They're also the preferred Hondata tuner/dealer in the area. Even if you're not local to them, it's worth a shot shooting Jeff an e-mail asking his opinion.
Old Jun 19, 2003
SuperNegro's Avatar
No its not OBD1 dont know where you got that from. CRX is NON OBD why do you think you have to do an OBD1 conversion a CRX to run hondata.
Old Jun 19, 2003
I stand corrected - all CRX's manufactured in 1991 were OBDI (that was the year that California first started requiring it). All previous CRX models were non-OBD.
EDIT: Just quickly looked it up. Older CRX's actually used OBD0. http://pgmfi.crx-forum.org/resources...ification.html. Regardless of whether you have OBDI or OBD0, Hondata has an application for it.
Old Jun 21, 2003
mk32382's Avatar
mk32382 is an unknown quantity at this point
I have a buddy around here that works at a shop. He had a B20 with an ITR VTEC head running 12:1 compression on RIDICULOUS internals. 10k? HAHAHA. He doesn't start losing power until around 10.5, and he doesn't worry about his motor exploding til around 12k. It's sick. He just keeps pulling and pulling in 1/2/3 gear. While you're busy shifting, he's pulling through 8k, 9k, 10k. He can run 10k all day. That was all in an ITR. His personal best was 14.48 (this is at altitude I remind you), and all things being said, he's conservative at the clutch.
He has since sold the ITR shell, and has dropped the motor into a 6thgen hb. Five or Six hundred pounds lighter. He's taking out those high compression springs, and is going to turbo it. It makes me want to puke.
*sigh*
Mike
carlinag13
Jun 18, 2015 09:49 AM
Aball93
May 16, 2015 10:11 AM
Rinzlor
Apr 24, 2015 10:33 AM
supercivic01
South
Nov 30, 2001 11:27 AM
