i have a question
i have a question
hey whats up, i have a question about my car. well i was going really fast redlining until 3rd, i shifted to 4th gear but then the rpms went all the way switching between 8 to 8 1/2 about end of the red for about 3 seconds. this is bad and somehow i guess it went to second gear going 80 mph. my car runs fine but i was wondering what bad things could happen
The bad things that could happen is a blown engine. You can bend the valves or throw a rod or something like that... the engines aren't designed to run that fast. Just be more careful when you shift on the redline.
WOW! that is TOOOO weird! i did the SAME exact thing today! i redlined third went to hit 4th and put it into 2nd! i dont know how! but i did! i guess im used to my short shifter (revo) which i had recently removed to take the car in for tranny issues.......but BOOOM 8500rpm for a few seconds! scared the CRAP OUT OF ME! thank god car still runs fine [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Mis-shifting sucks. The furthest I've redlined my car on a mis-shift out of 3rd was 7,500 RPMs.
It can happen easier on a 6-speed if you're hella used to a 5-speed for cars like the Celica GT-S, or even the RSX Type S. The GT-S has it worse though for it's retarded gear box.
DIY King
I did that once intentionally for only a very short while. Shifted from 3rd to 2nd and the rpm's were past the rpm limiter (7,000 or so), so I accelerated a bit more until I finally switched to 3rd. I remember going about 80mph before finally shifting up again to third gear. It's not too healthy for the engine, so I won't be doing that again. Although the tight tolerances of our ULEV engines mean that we can run at higher rpm's for longer than previous generation civics. Still though, not doing that will lessen the chance of your motor going out on you.
Quote
[hr]Originally posted by: SoNiCcIvIc
It can happen easier on a 6-speed if you're hella used to a 5-speed for cars like the Celica GT-S, or even the RSX Type S. The GT-S has it worse though for it's retarded gear box.[hr]
Quote
[hr]Originally posted by: Grey
Although the tight tolerances of our ULEV engines mean that we can run at higher rpm's for longer than previous generation civics.[hr]
DIY King
Quote
I never knew that... so there is some benefit to having a ULEV engine, hehehe... no wonder Honda says, "Rev it up" in their 2k2 Civic catalogue (for the EX Civic).[hr]
Quote
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
junkyardguy
Sep 2, 2015 06:07 PM
engine
