CIVIC EX 2002 ON THE TRACK! ADVICE NEEDED!
Old Aug 7, 2002
Rider's Avatar
Rider is an unknown quantity at this point
Hey...I'll try my civic ex 2002 on the track sunday......
Some questions for those who have take their ride to the track before......
1) What time on the 1/4 I can expect????
2) At wich RPM am I supposed to start ...to be sure not to drift...
3) At wich RPM am I supposed to shift
Any other advice will be appreciate =)
Amount of money is on this drag [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Thanks!! I'll post some pics and some time sunday night [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Aug 7, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
u can expect a time of about 16 secs stock. as far as shifting just dont kill it. or peel out on the start. goodluck.
Old Aug 7, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
remove your spare tire and umm have fun
Old Aug 7, 2002
mohawkboom's Avatar
Cool a fellow dude from Quebec [IMG]i/expressions/face-icon-small-smile.gif[/IMG]!!! Well running at Napierville?... Most 2k1 SI coupe guys run in the low 16's.. seeing as this is your first run.. Don't get your hopes too high.. Also..don't drop the clutch.. rev up to about 3000rpms and release the clutch quickly..but do not dump it..you'll bounce and lose alot of time.. Shifting.. redline it of course.... And don't try to speed shift or shift too fast..any bounciness in your shifting will cost you time.. if you must shift a tad slow so your not rushing it.
Cheers
Mohawk
Old Aug 7, 2002
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
Hey good luck... I plan on running my 2k1 civic coupe at the track on Friday. I am taking notes as well.
Old Aug 7, 2002
Rider's Avatar
This will be my first run at Pont rouge mohawkboom!! Have been showing the car at Nappierreville....but haven't put it on the track.......dude there run 13....=)))
Thanks for the advice all......! If there is some others advice...I'll take them =)
Thanks!
Cya!
Eric
Old Aug 7, 2002
mohawkboom's Avatar
13 for a few 99-2k SiR's yeah... Fastest run I've seen a 7th ge run was a 14.729 That's Martin from DPB Sports car, but he runs with custom cams Ported heads and a 75 shot of Nitrous..but his car has 40k km's and burns oil lol
Old Aug 7, 2002
Rider's Avatar
40k km =) ahhhhhhhhhh!!
Burn oillllllll noooooo =))))))
Old Aug 7, 2002
Rider's Avatar
Hey....another question... I'll put 195/60/14 tires under my car for sunday......i'm wandering if it is too small......insuflated with 15 lbs of air....is this setup ok?
Thanks all!
Old Aug 7, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
I've been to the track a couple of times and here's my advice: Infalte them to the mid 20's. 15 is too low. Drop the clutch around 4k to 4.5k RPM. Shift right before you hit the rev limiter...play around with it a few times to know exactly where it is. As far as the stagging lights go, the top two light up when u are fully staged. Then there are 3 yellow lights, followed by the green. Go when you see the 2nd yellow light up. So far I've done like 20 or so runs in all my trips to the track and I average a 16.5 ish. My best is a 16.3 Click on the link in my sig to se my car and its mod's.
Old Aug 7, 2002
mohawkboom's Avatar
I use the OEM tires inflated to 22PSI and I get some good off the line traction.. 15psi might be too little
Old Aug 7, 2002
Rider's Avatar
I'M taking notes =)))
Thanks for all the good advice!!
Old Aug 7, 2002
HondaLuver's Avatar
Its a celebration bitches!
what would an automatic ex with 18's, 4-1 headers, high flow cat, full exaust, cold air intake get?
Old Aug 7, 2002
C2i0v0i1C's Avatar
SuperMODrizd
times vary car to car driver to driver, 15psi is way to low, u wont do too good the first run, ull have to get a feel for things reaction times and such, and dont forget to watch the lights, and not the other person next to u, keep the windows up, take out the back seat and spare tire
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
Tybonater
Apr 24, 2015 07:03 PM
smmahan
Apr 15, 2015 08:17 PM
Myredjonda
Apr 14, 2015 07:00 PM
