EX/LX Exhaust System Swap.
OK from what I understand is that on my LX the cat takes up the bottom part of what would be a header on the EX, and the EX cat is further down almost under the car, could I buy an aftermarket header and Exhaust for the EX, and the EX OEM cat and hook it all together, and plug in my O2 sensor into the EX cat?
Retired - SoCal FI Mod
doesn't sound like a bad idea... but as i understand.. that would still be illegal... might as well swap it out for a hi flow cat instead... oem parts are expensive.. =(
heres the LX exhaust manifold system.
and heres the EX manifold system.
and here are the downpipes, the EX with the CAT and the LX without one
I want my car to stay legal, with all the cats in place, but I dont see how switching the location of the cat would matter or how they would know when inspecting in the first place. I just want to know if this is feasible.
Oh and if it is I would love to buy a persons who has a hi flow cat EX OEM downpipe, CAT, and the two O2 sensors.
Also another technical question, Why would the engineers bother making different headers for the EX and the LX? From what I knwo the closer a Cat is to heat, the faster itll heat up and start working, so why did they only put it right under the header on the LX?
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] 13S5P0_B02.gif (21 Kb)
End Bringer
i don't think the 16 was for generation, instead i think it meant 1.6 liter, like the b18, 1.8 liter. so the next logical spet should be a b20, a 2 liter, but now they got i-vtec, so why not put i-vtec into use? bam, k20 :-)
no i mean they used d16s in 6th gen civic LX and EX, and then for Si they popped in the B16, they didnt put ina b18 from an integra base, but for the 7th gen which for EX and LX use d17s they put in a K20, which is mor elike the RSX(integra) base, I just think its kinda weird. Honda getting lazy, I think the swap would be easier from new Si to EX or LX or DX if the Si used a b17 motor instead of the k20. Just my 2 cents.
i seriously don't think honda cares about how it makes your life easier to swap engines. what matters to them is the lower production cost. it's not like everyone that buys a honda is going to swap the engine.
That convertion has being done
The only part that you'll have to worried about is the second stage of the exhaust system right after the header, after that a good muffler shop can build a custom tubing to the back.
The factory tube is too small and you'll need a 2.75" tube to make the flow better and take advantage of the headers.
Another thing you'll have to do is to make an extention harnes for the secondary O2 sensor and placed right after the high flow cat. As soon as you remove the factory cat, your car will officialy be illegal so therte is no way arround it. (everything is legal till you get cut)
Click here for more pics 2k1 LX
GOOD LUCK
GOOD LUCK
Supermex has a ex header and exhaust. I believe all he had to do was extend the sensor cables to reach the sensor holes and everything else was plug and play. I think he has the dc header but I forgot what exhaust he has.
DIY King
Yeah, the front sway bar is the same in the DX/LX/HX/EX. For short, in all models. No problem there. Also, the DX/LX has the cat integrated into the header because they wanted to lower the emissions. Since the DX/LX has no VTEC, the camshaft is probably more aggresive and uses more fuel and air than an EX/HX. That's why they wanted to reduce the emissions. Or maybe it's not more aggresive, but the fact that it doesn't get more aggressive at higher rpm's means that the engine isn't as efficient in combustion. Therefore, they needed to clean up the air a little more than was necessary on the EX/HX.
All you really need is an EX cat-back, a high flow catalytic converter, EX headers, and a downpipe. You could use the stock downpipe, but that would be crazy. Just get a muffler shop to make you a custom one out of larger diameter tubing. Then just extend the 2nd oxygen sensor by cutting the wire and extending it. No problem.
Is thre a place in the hi flow cat to plug in the o2 sensors and also, i dont see what the problem is with getting the EX cat? And the car would still pass inspection. Also I dont want the engine check light to come on.
DIY King
Quote
[hr]Originally posted by: WhiteRiceBoi
Is thre a place in the hi flow cat to plug in the o2 sensors and also, i dont see what the problem is with getting the EX cat? And the car would still pass inspection.[hr]
the o2 port should go after the Cat for the computer to get the before and after gas/air reading.
Muffler shop can burn a hole into it the pipe and weld the nut that holds the o2sensor.
Is up to the shop to give ya a clean bill of inspection, we don't have Inspections in Florida so it is not a factor for us here,but LX/DX/HX are ULEV designated automobiles and for all practical propurses is cosider illegal to modify the exahust (specialy in California)
My suggestion is to make friends with the inspection shop $$$ [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
The engine light will not come on unless you start your engine before the job is complete, all sensors will have to be correct, make sure you mark the front and back sensors so you won't place them in the wrong port, if the engine light goes on disconect the battery for about 10 minutes. See DYI
Every mod is rice to you when you drive stock
www.ImportFactor.Com
Quote
[hr]Yeah, the front sway bar is the same in the DX/LX/HX/EX. For short, in all models. No problem there. [hr]
DIY King
Quote
[hr]Originally posted by: WhosYoDadday85
Oh really? One of the people on our team did that to his 7th gen (LX to EX exhaust conversion) and he had to replace the LX front sway bar....[hr]
so my question is, if the ex o2 sensors were purchased, would they reach where they're supposed to go on the ex exhaust, and still plug into the harness where the dx/lx plug into?
i'm not that worried about emissions, I just want to have a more efficient exhaust for my nitrous install.
Or would just a cat-back be enough for the nitrous, like a 50-70 shot?
DIY King
Hmm... Good question. I don't know, but why not just extend the sensor wires. All you have to do is cut the wire, solder on an extention, or clip on and extention, and you're ready to go.
hayden55
Jul 8, 2015 11:38 PM
fvckbg
Jul 7, 2015 07:08 PM
