Chirping sound when shifting
I have recently noticed a chirping sound when shifting from 2nd to 3rd. It doesn't seem to do it if I shift at lower rpms. It seems to be noticeable if I shift at more than 4000 rpms, and I have only noticed it from 2nd to 3rd. Does anyone know what might be causing this? I got a DC short shift adaptor a couple of weeks ago. Would that make a difference? Anyone else come across something like this?
it might be your tires skweeking if you are reving hard and switching gears quickly. if you ever go to the races you will hear the tires chirp when changing gears. Try a different approach when changing between thos gears.
I do it all the time from 1st to 2nd thats the sound it makes when you have so much hp that your wheels cant grip the ground or in our case your tires are getting bad so when you shift it cant grip enough if you were to get new tires i belive it wouldnt happen.
Quote
[hr]Originally posted by: SilverBUll8
I do it all the time from 1st to 2nd thats the sound it makes when you have so much hp that your wheels cant grip the ground or in our case your tires are getting bad so when you shift it cant grip enough if you were to get new tires i belive it wouldnt happen.[hr]
Can you tell where the noise is coming from? Is it comin from the outside of the car? The engine compartment? Or maybe the shift linkage assembly?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
this also happens to me, 01 dx with 10,500. Its not the tires, it seems to happen with the air on, only higher revs. just like what you said. I sorta sounds like a belt on say a riding lawn mower....
mg
mg
[QUOTE]Quote
[hr]Originally posted by: Rallye
Yeah, It does happen with the a/c on, and I have about 12,500 miles on my car. I can't really tell where the noise is coming from. It sounds acoustic, like it could be coming from the engine compartment or maybe outside.
Not sure.
Not sure.
It sounds like the belt on your crank and A/C and alt is slipping a bit when you go to put the gas back on after shifting. Try tightening up the belt by adjusting the position of your A/C. Sounds like it needs to be tighter. Take it to honda and let them have a listen too. They could probably hear it a lot better than I can over the internet.
15EXCoupe
Jul 30, 2015 12:59 PM
Jul 12, 2015 11:54 AM
fvckbg
Jul 7, 2015 07:08 PM
