guys who know nitrous
Old Jun 23, 2002
jamesbbh's Avatar
jamesbbh is an unknown quantity at this point
ok i got a NOS kit, no im not calling nitrous nos. thats the actual brand name. i have the bottle, steel braided line and 2 solenoids, what else do i need?
Old Jun 23, 2002
crazyjetskier's Avatar
crazyjetskier is an unknown quantity at this point
some cold spark plugs would be one of the things
Old Jun 23, 2002
jamesbbh's Avatar
no i mean like as far as the actual kit what else do i need? i got it ffor really cheap so i just need to know what else i need to make it work
Old Jun 23, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
THE Nitrous Post
Old Jun 23, 2002
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
I dont know myself, but fromthe way it sounds you dont know what you need, so your hopefully not going to try installing it yourself. Your tuner shop will tell you what other parts you "need" to make it work, and reccoment other parts that would be useful. They would know best what you need to get.
Old Jun 23, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
DONT INSALL YOURSELF!!!!!!!! unless your a pro at things like that
Old Jun 23, 2002
SoNiCcIvIc's Avatar
Quote
[hr]Originally posted by: sadboy619
DONT INSALL YOURSELF!!!!!!!! unless your a pro at things like that[hr]
I agree. Unless you don't know what you're doing, don't try to DIY nitrous.
Old Jun 23, 2002
01Ex's Avatar
01Ex is an unknown quantity at this point
You need the switch that turns it on at full throttel, What steel lines do you have? the one for the bottle to the solinoid? or one from the solinoid to the intake? you also need a "plug" to hold the jets and the jets. you will need a "T" spliter for your gas line. and a wire harness to make everything work together.
Here is what you will need.
Bottle
1 steel line that is as long as your car
2 smaller lines that go from you solinoid to the "plug"
1 other steel line that goes from your gas to you solinoid
a throttel switch
a turn on switch
a wire harness
a gas solinoid and a nitrous solinoid
a Nitrous filter
a Nitrous pressure gauge
your smaller lines are going to use a 4an style tip
your bottle to nitous sol. will use a 6an-8an style tip
so you will need tips(fittings) that screw into your sol. that fit those hoses.
a plug that goes into your intake
jets 35,50,75
that is really about it. Its not hard to install, I say do it your self. save money. its easy.
Old Jun 23, 2002
Spider883's Avatar
9K Redline Owns U
01Ex just posted everything u need. the hard part of install is the wireing so unless u know your stuff dont try it. just take it to a shop.
Old Jun 23, 2002
SlvrEX5spd's Avatar
SlvrEX5spd is an unknown quantity at this point
well i dont think i can help you to much w/ the NOS kit, if NX kit i could, good luck neway......and i installed my nitrous kit myself..never done it b4 and there was nothing to it. a little frustrating at time but all went well
Old Jun 23, 2002
jamesbbh's Avatar
yea thanks a lot guys , i can do it all myself i just wanted to make sure i had everything, anyone know where i can get 35and 50 jets and a gauge? im not going to have the throttle switch thing, ive got an arming switch already wired and im gonna have another switch by the shifter to juice it
James
Old Jun 24, 2002
01Ex's Avatar
Just because on FNF they hit a switch dosent mean that it is safe to do. you WILL lean out and blow your engine up if you do i that way. your car doesnt have a SAFMS and with out that you will never have enough gas to put in your engine to be able to shoot with out full throttle. all you need is an arming switch and a full throttel switch. You will be good to go.
As for getting the jets that you need call Summit Racing and they will get you what you need, along with all the other parts that you need. to save you some money, get a spool of steel line and make you own lines and what not. its cheaper and you can get it to the exact lenght that you want. just make sure you use 4an on the parts i said to and 6an-8an on the others.
anything else you need help with PM me and i will help you out.
Old Jun 24, 2002
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
well first things first...id that dry kit you got there or wet? since you don't have a return line fuel system a dry kit will cost more to operate.
Here's the run down...sell those things you got, and purchase a kit. NX is great choice since they make an awesome kit and even have a how-to on their website.
You need a wet kit since you do not have a return line system. If your intent with using a dry system you will need to modify your fuel system to have an adjustable rising rate regulator, and return line.
With the NX kit you can use a momentray switch that you can push on you own. As long as you use it only at WOT you WIll not lean out, unless other factors come into play IE bad fuel pump/filter.
The nozzle jets/ etc etc will be supplied in the NX kit. Only other upgrades I recommend are gauge, bottle heater and purge, all that can be had in their GEN-X upgrade.
Oh and if you can follow directions you can install a nitrous kit. No needing to be a professional for it [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jun 24, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
Quote
[hr]Originally posted by: crazyjetskier
some cold spark plugs would be one of the things[hr]
i talked to a guy in JD's imports about that. he says they are fine with stock plugs, (only 15k miles so far). just when i replace them he said go colder.
Old Jun 24, 2002
it would be in your best interest to go with 1 range colder plugs....stock can have the electrode melted in a night of drag racing. WHy risk the motor?
crowtoo
May 11, 2015 06:50 PM
MamaBear2015
26
Apr 16, 2015 11:08 PM
Cilvic
Nov 15, 2001 04:54 PM
wsking77
Aug 29, 2001 05:34 PM
