2door and 4door upper grill the same???
Old Jun 20, 2002
Ben's Avatar
Ben
Ben is an unknown quantity at this point
cause i just tore apart my bumper and grill to put on my altezza grill and this thing doesn't come close to wanting to fit. so is there some secret to it or is there to different front grills and i got the 4 door one?
Old Jun 20, 2002
Snowman's Avatar
Snowman is an unknown quantity at this point
The RS grill needs modification to fit the coupe. So they might be a little different. I don't know about the altezza grill. Try searching in the tech forum.
Old Jun 20, 2002
blackasnight2001's Avatar
blackasnight2001 is an unknown quantity at this point
i believe to get the grill to work on the 2dr you need to purchase the gray piece ( that it connects to) for the 4 door, its like 30 bux or so...
search around and you'll find the full info
Old Jun 20, 2002
Ben's Avatar
Ben
hmm well my neighbor has a 4-door so i'll have to llok at her car tomorrow to see wha is goin on cause this thing does not line up like the factory one. not a simple unscrew and screw on deal and yes i did a search but nobody actually says how they dealt with there 2 door...
Old Jun 20, 2002
VNlilMAN's Avatar
The Standard One
ya its just the back thats giving you problems, some replace it with the 4 door and other just take it off...
Old Jun 20, 2002
HippyCivicEX012's Avatar
HippyCivicEX012 is an unknown quantity at this point
So does the altezza grill fit the 4 door?
Old Jun 21, 2002
VNlilMAN's Avatar
The Standard One
they fit both 4 door/2 door its just a matter of whether or not you need to do some modification in order to fit...
i know the RS grill is made for the 4 door so you need to switch the back peice with a 4 door if you have a coupe. either that or just leave the black back peice off...
the altezza grill, i thought it was for 4 door but someone said it was for 2 door, not sure but if it is for a 4 door then ya you would have to do the same as above
Old Jun 21, 2002
Unleaded's Avatar
Unleaded is an unknown quantity at this point
so you have a coupe with the altezza grill? i have the altezza grill on my coupe with no fitment problems. if you are talking about the trim cover that attaches behind the grill, then no; your stock grill cover will not fit behind the altezza grill because there is a hump on it from where the 'H' used to be on your stock grill. you need to get the sedan version of the cover which is flat so it fits flush with your altezza grill. hope this helps.
Old Jun 21, 2002
Ben's Avatar
Ben
thank you thats all i wanted to know. i went to honda and got the part and everything is gravy. later
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
rnaodm
Sep 21, 2015 12:42 PM
FistRock
Sep 4, 2015 08:00 PM
