Do you need to roll the rear fenders if you get a camber kit???
Im getting the SPC camber kit and im not sure if my tires will rub or not. I have neuspeed sport springs and my tires are 215/40/17. Has anyone had any problems with their tires rubbing after installing the rear camber kit? I read through all the posts about camber kits and couldnt find a good enough answer.
You will have to have anywhere from 1º to 1.6º of negative camber, depending on the offset of your wheels, to clear the inner lip of the fender.
I have the Ingalls kit, currently set at -1.4º at the rear with a 2" drop and 17x7 wheels w/ 42mm offset. I clear the lip by just about 2-3mm--it works and it looks and handles way better than stock camber (just -0.5º, I think).
whats the need for a camber kit when using sport springs? i have neuspeed race springs and Im not wasting money on the kit. my camber is not that bad. you dont need to spend money on the kit if you have sport springs.
Quote
[hr]Originally posted by: dober
whats the need for a camber kit when using sport springs? i have neuspeed race springs and Im not wasting money on the kit. my camber is not that bad. you dont need to spend money on the kit if you have sport springs.[hr]
01IncaPearl: not only that, but when you rotate those neg cambered rears to the front, like you're suppose to, they really mess up your ride. You get the vibe in the steering wheel that you can't fix with balancing. Yes you need a camber kit. No doubt.
I'm going to find out this week when I finally have a day to get all my **** put on.....Koni's, Camber, F rotors & pads......I'm going to be a happy man....[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Quote
[hr]Originally posted by: SQCivic
Still need an explanation on rolling the fender to install a camber kit.[hr]
Apply it to my situation....If I have 215/40/18 tires...42 offset wheels...Neuspeed Sport Springs...SPC camber kits...will I need to roll the fenders after I install the camber kit?
Thanks for the help fellas, this stuff is new to me and I want to get it right the first time.
Quote
[hr]Originally posted by: 01IncaPearl
Then please explain to me why I had to buy 2 new tires for the rear. I can take some pics of the tires that came off and you will see that the inside of both rear tires were completely worn off. I would rather spend the money for the camber kit instead of buying tires for the rear every 6 months. By looking at my car from the rear I can see that I have negative camber and at $160 per tire Im not about to ruin another pair.[hr]
Quote
Quote
Thanks for the help fellas, this stuff is new to me and I want to get it right the first time.[hr]
I rolled my rear just to be safe, and I have 215/40/17. I had everything done today and I have no problems with rubbing at all. Im very happy with this purchase. I posted a review in the review section if you would like to read more on it.
Nalmonte
Jul 22, 2015 09:08 AM
OptimisticWay
Jul 10, 2015 04:31 PM
SpecialRequest
Jul 7, 2015 07:52 PM
