2009 Ford E250 Bank 1 Sensor 1 O2 Sensor
Hey guys,
Work van is throwing the following codes:
P0135 - O2 sensor heater circuit b1s1
P0030 - HO2S heater control circuit b1s1
Pretty safe to assume I just need to change the sensor?
Anyone here work on Fords? Been awhile for me besides oil changes
Is it fairly straight forward to get at? Pull the doghouse and it's right there?
Thanks in advance guys!
Re: 2009 Ford E250 Bank 1 Sensor 1 O2 Sensor
One code probably can cause the other, and a failed sensor heater could cause both codes
Most likely bad sensor, but I'd probably want to check a few things before tossing one at it.
Inspect the harness for the sensor first, any opens could cause both codes
You need to know which side of the engine #1 is on (and follow the exhaust pipe) so you don't replace the wrong sensor (incredibly easy mistake with some designs)
Sometimes sensor connectors could reach the wrong sides and swapped sensor connections can cause a damn weird running problem LOL
Hi Ezone
Thanks for the response, I had this cross posted in the ford forum I'm still a member on and got this response (from a Ford mechanic):
Harness looked good, it was on the passenger side, sensor was right out in the open once I pulled the dog house off.
I did throw a new NTK sensor on it (company's money) and so far no codes. In my limited experience O2 sensor codes tend to set pretty immediately.
Haven't found the fuse adsm08 mentioned, owner's manual is pretty vague, going to bring my meter in tomorrow and manually check all the fuses
Thanks again!
My experience with P0030 is limited, but I have dealt with P0135 many times and the issue was always in the sensor.
Dog box is probably the best way to get at it, but it should be pretty easy just sliding under too.
With that P0030 in there I would check the fuse for the heater circuit as well. It is possible that the fuse popped when the heater failed.
Thanks again!
(some manufacturers have designs which aren't monitored directly)
New sensor is in and working, therefore it can't be a fuse problem.
If a fuse covering the sensor heater circuit had blown, the sensor heater would not be able to work at all and it would have immediately reset one or both of the same fault codes.
Tronixx
15
May 17, 2019 06:16 PM
elpasovatoloco
Oct 13, 2013 09:35 PM
Vox
Buy, Sell, & Trade - Archive
Oct 14, 2007 09:52 PM
ryangt
Jul 13, 2006 06:27 PM
