How does car start?
Old Sep 20, 2017
gulzarh's Avatar
gulzarh will become famous soon enough
Question How does car start?
HI,
My question is about how car start. I mean when we put key in ignition that what happen,( what part get signal or electricity or become active etc..)
When we turn key to On position than what happen and when arrive to Acc than what?
My car was not starting at all and i was UNABLE to do anything because i dont know where and what to check and how to start and/or bypass in emergency case to arrive at garage at least.
I have paid another 975$ for repair, towing include, Yes 975$.
So if someone is interested to help me to understand in detail i will appreciate it.
i wonder if all vehicle have same starting procedure or different except to start with button and key.
p.-s. i have seen many video on YouTube but non of them are detailed.
Thanks a lot
Old Sep 20, 2017
Wankenstein's Avatar
Re: How does car start?
Your wording is a bit confusing. Are you saying it's fixed now and you just want to learn what the sequence is for starting an engine? OR are you saying it still needs repair/ still won't start?
First of all what year and model?
Automatic or Manual transmission?
Does it crank but does not run or is it not cranking (starter engaging) at all?
Old Sep 20, 2017
gulzarh's Avatar
It is repaired.
I just want to learn for next time.
Old Sep 20, 2017
Originally Posted by gulzarh
It is repaired.
Distributorless Ignition System:
Old Sep 21, 2017
gulzarh's Avatar
yeah i know that i already watched many of those kind of video but none of them is clear for me they just go straight forward. thanks anyway
Old Sep 21, 2017
i don't know, that was pretty straightforward. If I were to respond to your original question, my answer would have been similar to that video.
Old Sep 21, 2017
gulzarh's Avatar
i dont blame him or someone else here. i just have very poor English so i could not understand what he s saying, like ecu module, for me it is new i dont know what it do in car so if he say electriciy comming from ecu to this that i will be confused and stuck here.
but i am trying to watch some other similar videos to understand little little every day. thaks
Old Sep 21, 2017
just think of everything you do to start a car as a bunch of switches. When you turn the key, it closes a switch, allowing electricity from the battery to go further. In this case, when you turn the key, electricity from the battery is able to get to the ECU
edit: to be completely honest, there are a lot of answers you may get that are going to be much, much more than you would ever need to know. It may end up confusing you more.
Old Sep 21, 2017
robfarr56's Avatar
robfarr56 is just really nicerobfarr56 is just really nicerobfarr56 is just really nicerobfarr56 is just really nice
...and when you come across a term that you don't understand, simply type "ECU car" into Google search, and it will likely come up with a good definition. It may even translate it into French for you!
(I have learned A LOT that way, since joining this forum)
